NEO head
GT3540 Turbo
Forged 3.0L bottom end
car made around 340kw at the wheels on 18psi.
car makes boost at around 2800-3000 and hits full bost just around 3500-4000rpm. sorry if my estimates are a lil vague i havnt had the car back for long.
very very streetable....its almost as if there is no lag considering the turbo size.
unfortunately there is just absolutely no traction in most of 2nd and 3rd when it hits boost. it dosnt help that im running 19" Volks and it dosnt help that its got shit tyres.
but they are 9.5" wide.
i was planning on gettin some sort of semi slicks/drag radials ect ect but im worried that if the car does get enough traction, how would the drivetrain hold up?
how are the R34 GTT factory Drive trains with holding power? do they tend to snap?
any recommendations for putting the car tot he ground a bit better?
im considering getting some custom made 19x11 or possible 19x12 wheels made to aid traction on the rears, but its only an idea atm.
dont get me wrong the thing flies...but just very sideways :(
pics to come sortly :blink:
Edited by R34NRG
https://www.sau.com.au/forums/topic/221894-putting-power-to-the-ground/
try the obvious. better tyres, less throttle
i just stated that im lookn at getting better tyres but am worried about drivetrain issues......... and if im tryin to run a quick time down the 1/4 mile or anywhere else for that matter its pretty much useless talking throttle becauase it defeats the purpose of running a fast time. sure i can use throttle to a point where there is no traction loss but its stupid to the point that id run faster times in reverse. i understand what your trying to say but believe me when i say throttle is the least important problem ive got.
i dont want to sound like im trying to push advice away like everyone suggests i do all the time, but im just trying to point out that its not a throttle issue. i know for a fact its not the way i drive, its just the amount of toqrue the car produces and at the speed it does...it just dosnt work. it dosnt matter of its off the line or on a rolling start, as soon as the car hits boost its laterz.
i must stress though the tyres are very shit.
but i would like to start a convo on what ppl think of "Nitto" tyres. they have Sizes in 19" which is my only option, im not lookn at getting different sizes rim wise.
problem is they dont deal in Australia officialy, that i know of anyway. any one know where Their Range is available?
Edited by R34NRG
If you are referring to the nitto drag radials there are other things to consider, They will be very much like the mickey T's in that sure they will bite when they are warm but they will also have a softer sidewall which makes them bloody hopeless for general driving where corners are involved etc.
I am punching out around 370 rwkw atm and i have no probs hooking up. Good suspension and federal semi slicks work fine on my car. Sure I can snap it free if i want but driven properly it tucks and bites no probs at all.
As for your drive train concerns if you were worried about it why the hell did you mod in the first place.
In regard to setting up a 2wd drag Skyline, I posted this recently (that's why the Search button is so handly);
You want no more then 3 kg/mm rear springs, around 2.5 kg/, is better. You want rear shocks with very little low frequency bump valving but a large amount of low frequency rebound damping. If the shocks are a decent brand then you can leave the high frequency valving alone. The soft spring rate allows the rear to squat and absorb the torque hit, the large amount of low frequency rebound damping holds the rear down for maximum weight transfer onto the rear tyres. The problem is you get a lot of dynamic negative camber when you get enough squat, so you need to set the static rear camber slightly positive (around 0.5 deggres). A rear subframe alignment kit installed in the "Maximum Traction" positions is also a must.
Around 3.5 to 4.0 kg/mm front springs are OK (hardly "hard"). You want front shocks with a large amount of low frequency bump valving but with very little low frequency rebound damping. Similarly to the rear, if the shocks are a decent brand then you can leave the high frequency valving alone. The limited amount of low frequency rebound damping allows the front suspension to extend therebye reducing the weight over the front and hence more effective weight transfer to the rear. The reasonable front spring rate helps to hold the front tyres onto the track, you may need to steer at some point. The front suspension geometry is pretty much irrelevant, just make sure the wheels are pointed straight ahead (zero toe) so they don't provide too much drag.
In a general sense the average Japanese aftermarket coil over kits are not suitable for drag racing and the standard suspension is better. But (there is always a "but") the problem with the rear standard shocks is that they don't have anywhere near enough rebound damping. That's when they are new, let alone 15 or so years old. So you get bad axle tramp, the kind that breaks drive shafts. The more power the car has, the worse this problem becomes. In a standard'ish Skyline (boost up, FMIC, exhaust etc) you might just get away with it (standard shocks) on street tyres. But drag radials or slicks and decent power don't mix well with poor rebound control. You will spend more money/time replacing drive shafts than you will spending the extra on buying the right shock spring combo.
That should be enough to get you thinking in the right direction
Cheers
Gary
I bet the car is about an inch off the ground.
actually its still factory suspension. quite ridiculously high -____-"
worried dosnt mean im not gonna give up or anything. i just want to be prepared if anything was expected to happen. i kinda took it a step at a time, as i still got factory suspension i wanted to see how the car went. if it wasnt up to par i would mod accordingly after that.
sounds quite logical if you ask me :(
Cheers
Gary
as i am quite the noob in the suspension and drivetrain area. what type of modifications can be done to insure drive shafts stay in tact.
ive read countless times that nothing beats standard suspension for straight line drags to a certain extent. i know that coilovers are just to hard and dont offer enough "squash" effect. i could only see myself getting a shock and spring combo, but like i said above im worried about the drive train holding up when i do get traction.
so drive train wise where do i go from here? my options?
CHeers
How deep is your wallet. Plenty of options available. I am using a j/b full monty clutch. standard 25 gearbox. Custom hardy spicer tailshaft anda gtr alsd and half shafts. I guess my gear box is the weak link or so they say but it hasnt given a moments concern to date. If it does I will look to updating it with stronger internals.
There are a squillion clutch options out there as well as numerous g/box and t/shaft options. Do a search and you will find a group buy on carbon shafts ex usa. That might be more to your liking.
In the meantine dont cry until you get smacked. You might be surprised how strong the standard drivetrain is if you are not an abuser.
im running a single plate exedy clutch and it seems to be holding power fine. but its still sorta new so time will tell.
jsut curious though how much are we talking for aftermarket tailshafts? is it most likely the gear box or the tail that is more prone to break?
i pretty much granny my car, cant remember the last time i was on the limiter. just your average joe squirts here and there....
CHeers
We ran an 11.4 at 129 mph on standard drivetrain (+ Exedy clutch) in an R34GTT, so there is plenty of capacity in the standard stuff. Then you might find that you have to service the components, for example new standard drive shafts are better than the well used ones that you have now. If you start breaking new stuff, which is unlikely at your power levels, then you will need to look at upgrading. I haven't seen a lot of specific R34GTT drive train upgraded components. Personally I would go to a complete R34GTR rear end, subframe, diff, driveshafts, the lot. If you start breaking that stuff then you have an upgrade path with off the shelf stuff available.
Gearbox wise, if you are serious about drag racing then an auto is the only way to go, for around $3K they are impossible to beat value for money. If you aren't serious about drag racing, then a closs ratio synchro gearset is the first step, Trust have them amongst others. Then it's a close ratio dog selector internals from PPG ($9K) or Hollinger ($16K). The top level is then a sequentlial close ratio dog selector gearbox from Hollinger for a shade under $20K.
My suggestion, get the suspension sorted, buy some drag specific tyres (I use MT radials) and get out and have a go.
Cheers
Gary
Cheers
Gary
wise words SK.....as always
would u be able to offer more infomation on your radials? are they street legal? purchsed from MT directly? Price? size and profile? are they the ET streets?
would u go for anything else if u had another chance at buying tyres?
Yes, but I wouldn't drive anywhere with them on, other than from the pits to the track.
I actually got the last set from an SAU Group Buy, try a search.
Price?
It's in the Group Buy thread
size and profile?
255 x 16's
Yep
A full on drag slick would be better, but that involves ANDRA regs, front runners etc. A radial is much easier for us as we are not seriously into drag racing these days.
Cheers
Gary
have you thought about setting up an ebc (for street use) that build boost more gradually throughout the rev range?
with the 3l there should be enough torque to keep you happy...
also why get custom 11inch rims? there are plenty of options out there...
i just ordered tein ss coils for my 34gtt. Can i still tweak and set them up for traction?
Nope, their high frequency bump valving is far from ideal for drag racing and that is not adjustable.
Other mods will be R888's, rear camber kit, subframe brushes and hicas lock bar.
That's all OK, but obviously you would be much better off with a proper drag radial.
Cheers
Gary
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
