guys, i saw this link in the cosmetic section...
was wondering if anybody in Perth has gone through these guys and if they found that the fitment was quick and easy and what the quality is like?
http://cgi.ebay.com.au/LEATHER-SEAT-R32-R3...1QQcmdZViewItem
this is the link, i hope it works (it should) and ah... i've only read good things about these guys but the thread was 2 years old...
please let me know, would love to get onto this quick smart before AS as i'm sure most entering would be after the same...
so bloody cheap, let me know all your thoughts everyone thanks!
Andrew :D
https://www.sau.com.au/forums/topic/222238-interior-retrim/
everyone says it's awesome?
yeah i'm going to get buckets but i need $500 for rails... because GT-T rails are separate to all other R32-R34 rails :blush: fail :D
thing is i saw this pop up for $550 and thought it was a bargain, guess i'll take your advice guys, keep my car looking like a 'street' car
Edited by hoony
https://www.sau.com.au/forums/topic/222238-interior-retrim/#findComment-3917010
Ive see these seats covers/retrims on a Supra
a lil bit harder then my leather seats
but other then that they look great, feel great and still burns your ass on a hot sunny day
for 500$ its similar to 3k for a retrim
doubt your average joe could spot the difference
https://www.sau.com.au/forums/topic/222238-interior-retrim/#findComment-3917955
i installed set of these in my 34, i'd i must say i'm very impressed. To all those who say its plastic, tacky blah blah, unless you've sat and driven in it you cant really comment. I wasnt expecting a $3000 retrim out of these because at the end of the day i only paid a tad over 600 for the full set delivered to my front door. If anyone has sat in a r34, you'd know that the stock material is shit and gets dirty very easily, and mine was no different so for $600 i thought i refreshed the interior quite nicely.
Heres a pic of mine, like i said you cant expect it to be in the same league as a full leather retrim because its obviously not, but for the $$$ i think its very good value. I still havent done the front door inserts, just havent found time yet. Also even though they say its a DIY, its a very very time consuming DIY if you want it to look good.
https://www.sau.com.au/forums/topic/222238-interior-retrim/#findComment-3929283
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
