  • Replies 260
I think Adam and Craig should head it up
you dont start a tread about a topic saying yeah this yeah that who wants to organise it for me
grab each others phone numbers get together and discuss what you like its easy
haha thanks... id help but im not reali and organiser! lol
cara missr34 who seems to not be online these days is keen on going, and yeah i wanna hear how much were talking $$ i may bring out the night kids mobile im sure the intial d kids will like it there.
Cara is part of another display
Flick, just how much extra cost roughly was needed all up?
i think all the entrents chiped in like 40 or 50 bux, i cant remember but we had a friend set up the lighting and people that others knew as promo girls etc. but im sure the orginisers might have put in more and they really kept other informed about whats going on. we had a meeting and PK brough down a laptop with a layout of what they had planned.
there was so much going on but the orginiser took most of the workload :) thats why i said the people who run this one have some big shoes to fill.
Haha be optamistic!!!!
What would look cool is a Pimped R31 then a standered high powered GTS 2 door, the a Pimped GTST R32 then a high powered 32 GTR, etc etc and have an 8 car display.. mix of power and looks
its what we had last year, looks and power. but to win anything it needs to all be set up right.
goodluck!
^what kye said, all entrants put about $50 in each, but i chipped in a bit more and i know PK spent aloooot more again than me.
As i said, happy to help organize. Ill start making a list of who is keen to enter. PM me if you are keen so i can add you to the list. but please, think hard about it.. dont want to waste my time and effort if people start changing their mind or saying im a maybe etc. Its only a few months away and it will take that much time to get it sorted, believe me.
So pm me if you are interested and we will go from there.
yeas sorry guys wont be part of this years SAU display.......ive been organising my own display for a little while.
but good luck with it all.....try and get it organised asap tho early bird entry fee closes on july 11.
see you there tho :happy:
OK, I'll step up.
I am happy to organize the event if needed, but would greatly appreciate help.
Could you PM me if you have a car and will enter (assuming we get 4 or more cars).
We had a great display last year (I missed out due to a car crash) so how many of last years group have cars suitable to show (either power or bling)
guy, you need 6 cars minimun in a display to be judged as a group so that would be the minimum number to aim for. Hopefully you get enough, be good to see another decent display after the effort people put in last year.
Im pretty sure im gunna enter the LIMO just for shits and giggles this year. Unless a Drift event clashes with this years Autosalon.
I just want to put it on the Dyno and see peoples reactions. HAHAHAHAHAHAH
A big black limo thingy pushing 300rwkw's hahahaha
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
