  • Replies 71
I think you know my answer without me saying it.
With a wet system, aslong as your fuel system can handle it, you don't need any additional tuning or anything do you? Just simple as hitting the nitrous and the ECU will know what to do?
I had the same kinda question a couple of weeks ago, to get NOS or Water /Meth injection or Aftermarket Cams...
Water / meth injection won for me. But i allready have a big turbo gt3040 with 1.06 rear, so maybe you should get big turbo then NOS later.
Does any one have a dyno graph of a car before and after a nitrous setup, something like a 50 or 100 shot? Just curious to see what the power increase is like throughout the rev range.
100hp gas and 4-deg less timing = 100hp at the tyres more horsepower.
There's a bloke in the UK running an S12 with a single cam CA18 turbo with an 80HP shot of gas.
He runs consistent 12's - with everything pretty much stock.
See here:
http://www.aus12.org/index.php?showtopic=2715&hl=
and here
http://www.aus12.org/index.php?showtopic=2742&hl=
Imagine a boosted FJ20ET with a 100HP shot.
Might put a few skylines to shame :):P :P
Go with giggle gas buddy... It was a great trade off for me for drag racing. I was running a bone stock rb26 bottom end with a pair of T517Z's at nearly 400rwkw... sans gas. but at the track Í'd hit up a 50hp shot. It was great to launch with!!! It cooled my inlet charge and most of all allowed me to run mid 10's easily with a very streetable/small turbo package. So I had the best of both worlds... small turbo's for corners fun and a very fast straight line car.
It wont happen overnight...but it will happen :)
mmm... it will happen. Staged electronic nitrous controll to "soften" the charge. Low ish boost levels to keep the max cylinder pressures under controll. Individual injection per cly with propper distribution blocks and large duty cycle solinoids. Maybe even a seperate fuel system with methanol???
Could make for an interesting 8 sec lowmount car?
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
