Track 8 Megapixel Bullet Cam & Suction Mount - $100 !
BULLET CAM - 8 Mpix $80 !
Double Suction Mount $10 !
More info: TurboClub.com.au - BulletCams
PS, I dont sell these, but ROY you can borrow this one anytime!
Yeah, keep your shirt on Aaron, Sorry it was not supposed to go online.
It was just an internal test to link youtube to site but not meant to show your footage.
I would have asked you if I was intending to use you stuff as I ask every one usually or at least credit them.
As my camera gives better results than your film it would have detracted from it anyway. :thumbsup:
Sample coming soon...
lol, i dont care about the whole asking me and what not if you used it..i was just surprised you were advertising something and then using a totally different video to show its results
and..its a compressed youtube vid..i seriously doubt that any USB webcam will be better than uncompressed/xvid'd DV cam footage...however ill give you the benefit of the doubt and try not to detract from your product hey..
interested in seeing th sample..
eitherway..i like the bathtub grip thing :cheers:
Roy it would be a good location for rigidity but hard to operate
- not that you want to be playing with the touchpad when you are going down the backstraight at Sandown! :)
You are welcome to get it anytime to have a play with it and see what you think. Let me know...
Will try to get some vid soon on here.. I first tried it with AMCAP to AVI and 5min was 14 GIGABYTES! Great quality though! :)
Interested pending footage
Hey guy's I have managed to get some example footage 480 x 640 up on the following location as its a 5 MB file in WMV so not the highest quality the camera is capable of.
Visit My Website http://www.nissan-gtr-turbo.com/Bullet_Cam_Video/index.htm Example Video
The quality can be a lot better if set up to higher res etc but filesize can be extreme.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
