i know steering issues are a common problem with 32's and hicas is usually the thing the messes everything but i have read a few posts but don't really seem to be the same as my problem. what happens is when i start the car the steering is all good but after driving for about a minute or less the steering just goes all hard. it doesn't get any harder or anything like that it just keeps a constant hardness.
the steering wheel also is turned a tad to the right to keep the car straight. maybe a alignment issue?
anyway waht is the problem as its kinda pissing me off lol...like i can drive fine with it but just want to know how to fix it? thanks
https://www.sau.com.au/forums/topic/222710-hard-steering-for-r32-gtst/
You are heading in the right direction. Your power steering module is faulting, going into a failsafe condition. Hicas / power steering module same same.
Do a hicas diagnostic and see what it is, probably steering angle sensor, as it thinks you are driving in circles.
Your hicas fault light should be on though, maybe blown globe / disconnected / wiring fault? Will be impossible to do the diagnostic until you get that sorted.
just been reading few osme posts and mines differnet cause my steering wheel doesn't turn to the left after 80kmh, i haven't lost all power steering and it doesn't get harder as i drive. but i have a feeling its just all about the hicas.
does changing the steering wheel have any effect on hicas?
will lockbar be the best way to go?
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
