Well, I am currently taking an extended vacation, so I can do anytime, as long as advanced notice is given.
The car has been complied with HID intact and also is rego-ed. I spent this arvo putting on the front grille, clear side blinkers, bonnet gas struts and a cold air induction kit. I broke a few things along the way so I'll start a new thread and provide some pics with some commentary.
...Was a bit disappointed that the CF radiator top air difusser didn't fit properly on the sedan though....
Hmm, I should put my nickname on my details section such that u guys dun have to type out siu_loong_bao all the time.
proper compliance workshop shouldn't leave it intact... sounds a bit dodgy, I hope they do everything properly or it could cause headache down the way, not trying to scare you but sh1t does happen around... but at least half your troubles is gone as it's been rego'ed.
I think those air diffusers are more gimmicks than actually works...
Oh and we can call you Nelly if you want :P
Rianto, are you working on Monday (tomorrow)? Would be good just to compare keys as I am struggling to find even the same key model both on ebay Aust and ebay US....
I work every day, we're in the middle of technical go live with a project
before you buy any blank keys, talk to chris rogers on this forum because changing keys in v35 is not the same or as straight forward as in r32 33 34.
  • 3 weeks later...
So is anyone up for a small get together and cruise yet?
How about say Saturday 25th of July, have a get together and then cruise somewhere. Just to meet some of the other members and socialise in person for a bit! :)
All V's and M's owners that wish to come!!!
Any interest this time?
Rianto, we can do the meet at your place and say G'day to the bub! Hehe...
Maybe not a cruise then...but definitely a meeting spot with a big carpark (hassle-free parking) would be good...
previously some areas with large public parking would be around albert park, or somewhere near the Como park... but that's more suitable to people who live in southeast areas...
not sure about the west, I'm only here about 1 year... so perhaps somewhere at the far end of sunshine central but depending what day/time it could be very packed though.... or I'm not sure if opposite VUT Footscray there's a big public car park which probably is a bit ample during weekends, although it's a gravel car park so I just hope no mindless idiot in their RWD shitbox gets interested, pops in and doing doughnuts with gravel flying everywhere...
talk about stone chips and cracked windshields...
or what about horse shoe bend park's viewing area? I saw that area a couple of times when I past keilor park drive, seems to be a good viewing spot with ample space...
Yeah, just a meet and no cruise is good!!!
Where are we all at? Are we all over the place?
I'm in Carlton!
Carlton? hm....
how about Garage Cafe?
never been there so dunno how big their inside car park is, although food probably not the best said my friends...
How about Saturday 25th of July at say 2:30pm.
We'll catch up at Garage Cafe, have a coffee and a chat, etc.
Who can make it?
If a few cannot make it, we could always make it another day.
Let us know!!!
Who can make it?
Let us know!!!
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
