Strangely enough, the best ones are not from Shanghai - the origin of siu loong baos..... but in Taipei (Taiwan)...the place is part of a chain restaurant specialising in siu loong baos throughout Asia with stores in Singapore, China, Taiwan, Hong Kong...Even more stranger is that, although they all trade under the same banner name DING TAI FUNG, the original 1st store opened in Taipei is the absolute best with such good service....
And, in the event that one gets served to you broken withe the soup leaking, it gets replaced...Now that's customer service!!!
As to Melb, I am sorry to say, but the ones you are eating are nowhere as near what a siu loong bao should be...
A successful siu loong bao must comply with the following:
1. steamed fresh and served within 2 minutes....the longer it is left after being steamed, the more the skin dries out....
2. must be made of FRESH ingredients, especially with fresh crab meat....to give that fresh, sweet, non-MSG flavour
3. Steamed under a silken cloth, not under a cabbage leaf or wombok leaf...
4. when picked up with chopsticksticks from the bamboo steamer, the skin must be almost see-through in colour (meaning very thin layer of skin), yet does not break whilst being picked up, and has a bouncy/chewy texture....
5. Must contain a high quality broth inside...and to burn your mouth like an exploding bomb when you eat it...LOL
6. Must be served with a high quality red vinegar and finely grated ginger....
Anyway, back to the meet....any other takers????? Come on...join in...MILLOS really wants your business at the car wash...LOL...
My, such intricate knowledge of such delicatessen
You are indeed the 'siu loong bao' man!
  • 3 weeks later...
Hey Rianto,
Still hapenning, as per the original post the deluxe car wash will be 50% off on the day. Deluxe = interior, exterior, windows, tyre, dry including door seals, etc, the works pretty much.
As per cut & polish, details, etc. I will be providing everyone attending a VIP card for V35's with a special discount on all services offered.
But definitely looking forward to the meet, hopefully it won't rain, hahahaha.
yeah, that would suck big having our cars washed only to be rained down a few mins later...
but if anyone doing a cut & polish that'll be the ultimate test as a good polish would cause the rainwater droplets to fall off the car like pearl droplets, leaving the car virtually 'dry'
So guys, less than two weeks to go now.
The list is as follows:
1. MILLOS; Pablo
2. RS73, Rianto
3. siu_loong_bao, Nelson (I may skip the long cruise to Mordialloc)
4. scorp; Sam
5. missV35; Fiona
6. xscape237; Brad
7. pw350GT; Yun
8. japav;......?
9.
10.
Add your name if you have not already, or delete it if you cannot make it.
Date: Saturday 5th of December
Time: 10:00am
Place: Blue Water Hand Car Wash, 468 Mt Alexander Road, Ascot Vale
Cruise: Travel to St Kilda (via Lygon Street) and cruise down Beach Road to Mordialloc. (Just an idea)
List as follows:
1. MILLOS; Pablo
2. RS73, Rianto
4. scorp; Sam
5. missV35; Fiona
6. pw350GT; Yun
7. japav;......?
8.
9.
10.
This Saturday now guys, anyone else interested??? japav, what's your name???
Fox you still coming to Melbourne?
I'm actually in Sydney now and will travel back to Melbourne on the 2nd also, 7:30pm flight out, what time are you flying to Melbourne?
yesyes im still goin to mel!
actually my flight is today...hmm...is already 1st dec now so yea. tonight at 9:15pm.
ill see u in mel~
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
