alrite~ as promised here is some photos~
really pain in the @rse for uploading here,
I've also upload most of the pics to my facebook album(so much easier to do in facebook~)
http://www.facebook.com/album.php?aid=1688...mp;l=7348c5885a
edit: fixed link.
Edited by Japav
Great to meet up again everyone. Sorry I couldn't stick around for the cruise but promise I won't pike out next time :ninja:
Great photos guys and vid Rianto... good to see you got that dodgy electrician working on Juan's car :ninja:
Edited by scorp
Guys, I will aim if not earlier, in the next Melbourne meet, for a chance to you guys who have factory navi/tv and wanted an english conversion - it can be done now, I am playing with the screen functionality on my car as I am writing this post.
However depending on time (8hr time difference between here & moscow) it may have to be done over 2 days minimum. Ideally is 3pm onwards.
It's an activation based 'service', in which a first part will be installed to generate a unique code. The developer will only activate the unique code through Andy (NSW), Chris (QLD) or me (VIC). This was to prevent 'piracy' so the developer get paid for all their hard work over the past year working on this.
We don't actually give out the disc as each install code is unique to each vehicle's time & location of installation and only usable once, and after it's activated the activation code is of no use to other vehicles, and basically is discarded. So it's not like buying a retail box version of Need for Speed game in EB Games :-)
Due to the time difference with Russia & the time of actual installation, activation can happen on the same day but if timing is not suitable for you then it can be done on a later day. In between activation process you can drive around your car for days without worries.
Ideally we want to go through the process after 3pm in the afternoon as that is the best window of time to get things done with the russian programmer.
let me know when you're in melbourne, pm if necessary, i'll see if I can fit. i'd rather wait till the patch to the DST algorithm is completed so I can install the latest version into yours, but even without it all the screens you need will be functional, and the patch can be applied anytime later.
Hey guys,
new V35 owner here. Picked up my Silver 05 Update Premium Sport last week with 44K on the clock. Live in the south east (seaford), work in carlton. Would love to meet you guys at the next meet.
P.S. Rianto, that was me emailing you earlier tonight about my display screen.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
