Couldn't wait for the R20?
There good aren't they...
I didn't test drive R20 (they're only called 'R' now) but the spec looks good and I'm sure it's blistering quick for a practical hot hatch.
But I can't justify spending $65k on a small ex-demonstrator wagons that dealers have leftover loaded with leather sunroof navi cos they're too expensive and no one buys them, and waiting on back order for 6 months is way too long...
$20k difference is a lot of money
R20 from what I understand...
I don't think you can test drive an R20 in Australia as they are not here yet are they?
I drove the old R32 and it was good... the new R20 is a full second quicker to 100... now 5.2 secs
Your right about the money though and the GTI is so close to it... except the 4 wheel drive.
A WRX, EVO or even a Turbo Forester is much beeter value but the GTI is niocely screwed together.
Did you go the DSG?
they are in stock, in very , very limited numbers.
No they're not called the R20, they're simply called 'R' - I think due to some marketing decision that VW don't wanna go down in number from R32 to R20... the R is 188kw with AWD system. There are 5 in Victorian dealership if you wanna try your luck test driving one of those...
http://www.carsales.com.au/all-cars/result...&Ntk=CarAll
and out of 5, only 3 has 5 doors so that limits down my option. out of 3 that has 5 doors, only 2 has DSG so that cuts down my option down even further between 2 $65k small hatchback... even with extensive haggling don't think I'll get much luck to get it under $60k ever, and even if I do, $15-20k more to spend than what I am willing to is way too much money and can't be justified for.
oh and regarding the wrx/forrester, never a fan of them, especially since the bug eye styling from then onwards IMHO the impreza styling has gone backwards, and the current model has clear/silver taillights a-la Lexus IS200/300 / RX350 which I am not a fan of... give me a hot, burning red tail lights, not one of those disco ball silver reflector tail lights... yuck!
yeah, I went with the DSG, 5 door, as the main criteria is my wife must be able to drive it, and must have rear doors for easy access to put the baby seat when I need to.
nice and good responses... I agree about costs.
STI money too but you don't like them!! haha
Turbo Forester would be my pick for a 'family' car... slightly less than the others and so much stuff included.
wish they we a bit less rolly polly tho.
5 door GTI good though and nice choice
Well I guess another person won't be joining the cruise... Nelson aka siu_loong_bao has sold his V35 sedan... congrats by the way...
and being in Canberra it'll also make it harder for him to come down just for a cruise...
  • 1 month later...
Anyone fancy sorting out a Melbourne V meeting?
Please post any ideas about where to meet and what sort of meet would be of interest.
i.e. Cruise, BBQ, Go-Kart evening, vineyard tour etc.
If I can get a handful or so replies, i don't mind organising it as long as we have an agreement on the format.
Ok I have a 2003 V35 silver premium coupe (28000km) with sun roof, english conv and the lot and am feeling rather lonely.
I have just fitted factory (chris) cruise control and it is fantastic.
Every time I take the car out it is amazing and draws comments from others.
It is far too fast for me and hugs the Mornington peninsula roads like glue.
Aurthurs seat ride is awesome.
I have a cat back ready to go but think the existing system is cool enough.
What is next?
I am thinking of selling and getting a Patrol....a jag....or what.
Once you have had one of these nothing really compares......and I have had 3 * 5.7 and 6.0 l ss's.
G
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
