Stephen T...yes, a Dualis +2...full leather, full panoramic ceiling glass, auto everything...+ 7 seats when I need it...
Rianto should hv bought a Dualis...:)
To be honest, I don't miss my V35 one bit....
Lol can't do it that quick mate. Set a date a weekend preferable :)
I don't mind meeting with the Z group
It will have to be in November, I'm off to Europe with work for a few weeks. I figure 20th or 21st of November would be good if we are planning a V series Skyline meeting. Alternatively we can tag on to the Z club meet. The next Z club meet is a cruise down to Portsea. They have not set a date as yet.
It'd be good to gather a bunch of Vs and join the Zs for a Portsea cruise.
Like another car wash meet?~
Did my car this arvo was quite painful being no wash at all in winter season and arms get too tiny for polish/wax,
could've get someone to do it for me~ :(
Being Black, my car hates the commercial car wash. I have to do it at home by hand every week!
  • 2 months later...
Guys,
I just got my V35 sedan three weeks ago. Quite keen on a cruise and the proposed date of 30 Jan is fine for me (if you guys don't mind having a sedan tag along that is :-))
Sound gud thats mY day off
Keep us postee
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
