What a f**king retard. But you see GT-R badges on anything and everything these days. I almost thought about hitting a guy who had GT-R badges and the GT-R rear wing on his NA R33.
Yes here is another prime example sourced from a carsales ad Infinity badge on the front grill Skyline on the back top it all off the owner added a GTR badge ? i think the owner is confused with the car's identity.
Edited by MFC05
damn these new Nissan's are dead set ugleh.
Has anyone thought of wasting heaps of money an buying a micra and transplanting the engine with that of a Sr20, RB26, VQ35??? LOL....that'd be madest car around! Nismo should take on the challenge :geek: *Introducing the new Nismo Micra S -Tune* :ermm:
To see the faces at the lights when you spool your turbo's for the green would be priceless! If only the engine bay could be a lil bigger *takes out project book and thinks*
Unless its Top Secret's AWD V8 V35 "GT-R", that's just retarded.
I dig the bodykit and rims, although I don't think the Nismo stripes suit a "grand tourer", but that GT-R badge and the hideous reversing camera ruin the whole car for me.
Nissan UK has.
They used to have a Micra with a mid mounted SR20DET, and recently they made one with a VQ35DE.
I think thats the twin turbo one in Sydney. Haven't seen the add for a while but it's around $90k and i think it says something like "as close as you can get to GTR beofre they'e released'
Back on topic that Z looks really really bad
Nissan UK has.
Was about to say aswell, sounded like a freakin monster too when he put his foot down
You're both right :blink:
soo a turbo vq must > everything by that logic :ninja:
Quite possible, but I'm not sure unless the photos are very new.
I spoke to Powerplay around 3-4 weeks ago, who've dealt with the owner of that beast V35 twin turbo, and when they last saw that car it was still running a stock front bar.
However, the wheels are definitely the same and it does look like an APS intercooler visible in the grille of that aftermarket front bar. The TT one also had that reversing camera.
rb20e > VQ38dett
VR38DETT> RB26DETT > VQ38DETT > RB25DET > SR20DET etc etc etc.... > than a bicycle > than using legs > being disabled > than being dead!
Also im not suprised about the nissan micra thing! thats why i asked.... now all thats left to see is the Nismo racing stripes painted on a wheelchair and im set for suprises....
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
