Hi All,
I've done a bit of google farming without allot of success, so thought I would throw it to the general forum populous.
I have a R34 GTR V-Spec II. As you're aware, the V-Spec offers a couple of extra features including 2 x extra sensors and the MFD upgraded to utilise these sensors. Namely, they are the Exhaust temp gauge and Intercooler gauge.
My situation is that really I have two problems. The first problem (and if anyone can help with this, great! but it's not the main topic for discussion) is that my boost gauge is registering at 0 at all times, and does not pick up any boost. I had a friend advise me that the MFD needs recalibration, so off I went down the path of recalibrating based on Nissan instructions. The recalibration worked just fine, but it didn't fix anything - and to make matters worse, when I powered the car on after the recalibration I had lost my 2 sensors.
So it would appear that the MFD has reset to a non-V-Spec configuration, and has removed my Exhaust and Intercooler temperature gauges.
Can anyone advise on how to get them back?
As a secondary, does anyone have advice on the boost gauge problem?
I've had the car for nearly 4 months now without fault, so this is the first (and hopefully last???) for a long while I hope. Any advice would be appreciated.
Cheers
https://www.sau.com.au/forums/topic/223258-r34-mfd-reset-losing-gauges/
its because you ran a diagnostics on the MFD when there was no reading input for exhaust/inlet temp.
drive the car around to get your exhaust temp and your inlet temp up. then run a diagnostics.
it should look like this
if you dont no how to run diagnostics here it is.
Diagnostic mode
1) Turn the key to the "OFF" position
2) Push and hold the joystick
3) Turn the key to the "ON" position while still holding down the joystick
4) Release the joystick at least 1 second after the "GT-R logo" appears.
5) Click the joystick 5 times within the next 3 seconds.
This will show which sensors are functioning and have readings.
Hey mate - spot on, worked a treat.
Thanks for the great advice!
Any guidance on the boost gauge issue constantly showing neutral pressure?
Thanks
do you have any other boost readings in the car apart from the MFD?
if you do, are they all working? or is the MFD the only one with the issue.
Edited by R34NRG
unfortunately the MFD is the only boost gauge that i have in the car... so no definitive answer there :P
unfortunately the MFD is the only boost gauge that i have in the car... so no definitive answer there :)
thats a bummer, are you running a boost controller!??!?!
all i can say is check your boost sensor in the engine bay. and make sure there are no leaks or anything.
have any tips on where the boost sensor is? the car still boosts fine, it's just the gauge.
if you can give me a hand with letting me know where the things are, i'll get it checked out..
usually on the firewall, up in the corner on the drivers side. little black plastic box about the size of a matchbook. it will have a little rubber vacuum hose running to it, 1 set of wires running out too.
  • 3 weeks later...
Hi all,
Have a similar problem but not with the boost mines with front torque to be honest i think there are one or two that don't show any reading at all i have gone into the diognostic mode and front torque still lights up green so i have no idea why its not working its actually scaring me maybe my alttessa is not working???? (this is my first GTR had an EVO7 before) oh yeah my car is a R34 gtr Vspec
Sorry for hijacking but thought its relevant.
Andy
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
