Hi Guys,
Ive been reading about people doing their own conversions of RB25 or RB26 into a R32 GTST. Im not sure what to go for, a 25 or 26. Im not chasing HUGE numbers around 220rwkw would be fine so a 25 would be a good choice.
From my research it appears i need the following,
RB25 Engine and Loom
RB25 Gearbox
Diff??? (Not sure)
Heavy Duty Clutch (A want item)
Where would be the best place to have this done, I know its a DIY job but im not very confident in doing it myself. Any information or help would be great.
Thanks
had mine done jan
diff you don't need to change. heavy duty clutch, maybe. depends on what you get with the engine and gearbox you purchase. you may get lucky and already have one fitted in there.
you will need to modify your tailshaft. I had a custom one made up for $550, but you can modify your original one.
apart from that, can't really recall needing anything else.
Ok will call signature.
Based on me having the engine and gearbox already what figure (ballpark) would i be looking at to have old engine+box pulled and 25-26 + box fitted.
Also what price would I be able to sell my RB20 and box for it has 90,000kms
If you can get the box and motor out yourself go see Murnane Motors on the coast they charge $5000 to sit a RB26 between the strut towers and weld up the front diff for RWD and make a dump pipe - in a R32 GTST.
Dont expect anything to be hooked up you are expected to either pay them more money or take it somewhere else if you want the car running...
If that does not sound enticing go see Mick @ Signature or wait till Dan (Elite Racing) slows down a bit, I believe he is into that sort of thing...
Few options there for you, Every performance workshop can do the simple RB Engine conversions
Just be careful because service/price/customer satisfaction differs greatly depending where you go
I have about $5500 to get the engine + box, I guess a RB26 is out BUT a 25 will do nicely. What the hell im going to have a crack at it myself.
I will do pics ect as it progresses.
NOW for a question, Who can i go see to Connect everything up and make me a custom tail shaft
220rwkw?
for the $5K you have to spend, you could make a reliable 250rwkw out of the RB20.
without the hassles of rego paper work, engine swap, being off the road for ages etc.
to make 220rwkw out of an RB25 you are going to need upgraded....
intercooler, fuel pump, afm, injectors, turbo, exhaust, ecu, tune
now, if you buy the above parts for the RB20 you already have, you will still make over 220rwkw and not have to fork out for the purchase of RB25, gearbox, tailshaft, engine swap costs.
If your goal was on the crazy side of 250rwkw, i'd understand the need for more capacity.
just a thought mate.
I think spending the cash on the rb20 will yeald good results for less money.
have a look in to the RB20 dyno results thread in the forced induction section to see what mods make what power on peoples cars.
220rwkw?
Yeah i have have been looking at the dyno results for RB20s with upgraded bits. What im unsure about is the torque low down. Everyone is saying how much more power the RB25 makes over a 20, I had a 33 GTST with a bit of work done it was decent. But if a RB20 will make the power im chasing maybe thats the best way to go.
Will i still need a 33 box to handle the power>??
need for gearbox depends on driving style.
see the car in the vid in my signature.
260rwkw
stock rb20 block and head.
td06 20g (8cm)
ecu blah blah blah.
8800rpm
22 psi (I think)
stock rb20 gearbox
The details of his motor is in that rb20 dyno thread somewhere.
it's Roy's car.
Edit - here is his post
http://www.skylinesaustralia.com/forums/in...t&p=1895402
Edited by GTST
Depending when you plan to do the conversion, I can offer to do a plug'n'play loom for you. Send me the RB20 and Rb25 looms and I will return it ready to simply plug in and go. I wire up all items to ensure complete functionality of the standard RB25 ECU (eg. boost solenoid, VCT, FICD, A/C etc). I normally charge $300 for a series 1 or 2 RB25 or RB26.
I have personally done the RB25 into R32 conversion twice and can recommend it. The RB25 gearbox will require more work and if you already have a manual R32 you will need to either modify the gearbox crossmember or make a new one. If the car was originally auto and you plan to use the RB25 gearbox, from what I have seen the original crossmember should bolt up ok.
Cheers
That is the biggest rip off I have ever heard of :) spend the 5k on mods for the rb20 240-250kw easy :D
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
