  • Replies 461
Posted Images
Wasn't WA Susp that paid for it,
Matel are picking up the tab...
You know the guys that have commissioned an action figure based on the awesomeness of Mike's fighting prowess on the Battlefield, the Bar,The Dance Floor and the Karting Track!
G.I Mike The Greatest Hero Of Them All!
ahh didn't you hear
Mattel has issued a recall on the G.I. Mike something about it not saying on the box that it is not for children under 12 years as it contains SMALL PARTS
Nice one.... But I know it is small....
I also know it works (1 X Man Cub)
It is my weight saving committment to the Karting Day for Team RamRod!
this is true at least we know you are not shooting blanks
Trying to make him think that I care.... Which I don't
Hoping he (Mattley) will believe that I / We are going to take it easy on him instead of handing out a massive reaming..... Oh and then beating him on the track!!!!
Mike/Bard - you had better go practise this weekend or come and injur me, or both... I have just printed up team Green Wang Pump Racing decals and they will surely add 3-4Hp to the engine and vastly improve aero... I also boooked into the local GP to remove one of my balls cos its only going to take half a man to beat you guys... it is also saving me at least 6kg of balast!
* Sneak into Scotty's bedroom, opens smelling salts and snaps fingers....
"Wakey Wakey Scotty,
Your dreaming again.....
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
