I have never seen that before! he's keen!
http://www.khturbo.net/images/Z24images/Ph...-6%20Phase2.jpg
http://www.khturbo.net/images/Z24images/Z2...12-9-05%20B.jpg
um... soo... would it work well? i cbf reading all his writing... not that Im getting any ideas... but interesting thought...
I've seen it a lot, it's pretty common with Corvette's. It's to do with engine bay size restriction. I've seen them mounted just near the transmission on newer Corvette's. Dunno how it would go with response though but maybe that HUGE V8 makes up for the loss.
Tight squeeze!
http://www.vetteweb.com/tech/vemp_0802_c6_..._kit/index.html
Interesting.
The Yanks got some different ideas.
I noticed the car does not have an intercooler.
So the way I see it, by installing the turbo under the car on the outside, (Cold) air can easily get to the turbo.
Also since the turbo is exposed to the outside air, the turbo housing can act as the intercooler.
Only down fall is if the car is too low, something might hit the turbo and the pod will suck in a lot of dirt and shit from the ground.
funny because the link you posted says they are certified and legal in some of the usa states...thats pretty cool..
epa would have a field day with that here :)
no mufflers, external gate, yet its ok for US emissions..sucks to be us
Not to mention water from puddles etc.
True, sucking water is not a good idea.
epa would have a field day with that here :D
And the USA were not allow to import the R34 GTR because it did not meet the USA emission test... :)
Here is a Mustang with a similar application, air cooled turbo.
Edited by (00)SKYLINE(00)
Yep a tuning company over in the ol' US of A has been doing this to BMW's for ages. They were also placing the turbos right at the back of the car.
When I questioned the lag of such a setup it was pointed out to me that as there is almost a constant flow of exhaust gases to turn the turbo it is almost constantly providing boost and hence the lag wouldn't be as noticable as you would think. I wasn't entirely convinced but it does make sense.
bah, i would have thought that it would face the same problems in terms of response as any other turbo. The big difference being that it has to pressurize an extra 2.5m of pipe before entering the inlet.
If u got pulled over here with that setup because the officer thought you had illegally turbo'd your Excel or something you could pop the hood and say "Look, no turbos!" He wouldn't be able to see them either without a hoist if it's in the midde of the underbody.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
