yeah, no way is that road legal. the belt will be coming around the headrestraints and end up in front of your face, which means you need to use a 4 point harness which is illegal on the road.
we are really talking track seats here though, so road legality is not an issue. personally I have a race seat set up on it's monuts and harness and just swap it out with the road seat as needed. takes about 10 mins.
  • Replies 42
Posted Images
Even if it's legal, a harness on the street would be an absolute pain in the arse, it really stops you doing a lot of things... forget about reaching into the glovebox or the back seat!
That's a nice looking seat though
What is a half decent fixed back "big bloke" seat for a dedicated circuit car just for private trackdays? It's easy to find decent cheap (about $750) seats for regular jap sized blokes but none that will fit a real aussie bloke grr
Velo Podium are real comfortable and priced in that range, but are pretty heavily bolstered. The Velo GP90 is a great all rounder as it has slightly less leg support so makes access/egress a little easier. I used to have a Velo Esprit, really liked it, was a great seat and actually lighter then my kevlar Momo, though not as rigid. Shame they stopped the Esprit range
yep, velo GP90 would be perfect for what you want ben. very good quality seat, and made in aus. plus they have different sizes and can accommodate the 'ample gentleman'. they are in your price range too from memory. :P
Racer Industries are not exactly cheap either. Try Speedzone. Speedzone in Ballarat are typically cheaper again then some other Speedzone outlets. Hell for you Old Son i will get my housemate to pick it up as he is always in Ballarat, and i get it to you however, whenever in our coastal travels
Yeah, they're not cheap! Their seats are nice. I sat in one the other day and it was a very similar fit to my seat.
I've been buying OMP gear from Europe.
Just bought a couple of harnesses and some racing booties.
I haven't gone out to physically look/sit in seats just getting an idea of what brands/models to look at. I need to get a seat+harness for when I take my car in to get caged up so he can fit it all at once but i've spent $2k on tools and $1k on engine bits in the last 3wks so that could be a month or 2 away yet lol :thumbsup:
I'd be happy to sacrifice difficulty in getting in/out of car (with side intrusion cage bars) caused by higher sides on the seat if it meant it would hold me in position tighter.
yeah forget revolution mate. they are about as pricey as it gets. race and rally speedzone in greenacre are the way to go. nice guys there and better prices.
i'm not sure if they do velo seats or not these days. otherwise peninsula sports cars at brookvale carry heaps of gear and those guys will always cut a good deal.
my pick for you with your budget would be the GP-90 and a willans 3 inch 4 point or 6 point harness. you can get the 4 point then add the nut strap later if you so desire.
The OMP WRC could be ok too, a bit more exxy though at around $1000 and don't forget you will need side mounts, sliders and base frame too to mount it all.
I was planning on getting my mechanic to custom make welded side mounts so that it will sit practically on the floor because I will need all the headroom I can get with a cage + helmet in there.
good plan big fella. you will need all the room you can muster. piss off the headlining too. it's nice to remove weight so high in the cabin, helps with centre of gravity, and will give some headroom too. just make sure you are comfy when the seat is fitted! and add some extra holes in the sidemounts BEFORE you fit them so you can adjust the position a little if needed.
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
