A part you buy and use once, got heaps of them kents. Or I'll try and make something to do the job :)
ill be creating some contraption out of scrap parts and multiple tools to get some thing, and my old man will go into the shed, grab some gadget still in its packet and start trying to use that. some times works, usually the contraption is better tho lol
yep, just as i thought... background shows the ammount of fail this years autosalon has to offer. apart from chrises 32... hiding back there somewhere, that car is tough.
Edited by SkyHi_33
i havent been to 1 for a few years, ill head out n take some fotos 4 u >_<
girls only thanks.
if i wanted to go see a rice cooker id head down to the good guys :D
Edited by SkyHi_33
girls only thanks.
if i wanted to go see a rice cooker id head down to the good guys :woot:
I have to admit that I'm not a huge fan of metallic purple Subarus slammed on 26" chrome wheels with rubber bands for tyres.........I'm sure there would be some tough rides down there though to balance the bling out.
I've always gone by the motto that less (subtle) is more.......a sleeper on nice non bling rims (and def no GAY ghetto drift skirts) is the ultimate in car appeal and tends to not attract the wrong kind of attention. :laugh:
  • 5 months later...
nice one Vu
you best be bringing it to the nationals :D
Cheers Steve!
Very keen to go if the car isnt giving me any grief at the time :laugh: would REALLY prefer to tow the car there... damn the Kluger having only a 1500kg towing capacity!
Nice pics there Vu!
Piece of advice - when I put an aftermarket radiator in my R34 I noticed a HUGE INCREASE in water temperatures. Worked out is was due to not having a shroud over the fan. Get on this asap!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
