Beautiful car Martin!
You still live in the same area? Haven't seen it around, nor the GTSII for that matter.....
Thanks mate, yep still around... GTS is hibernating but GTR gets driven a bit - usually weekends but been a bit shit last few weeks!
heya gents picked up a nice daily for the wife she very happy BUT she not allowed to drive it until we sell her vz as the rego ran out on the 33 and theres still a few months on the vz haha
link to vz please spread the word http://www.carsales.com.au/private/details/Holden-Commodore-2006/SSE-AD-2247248/?Cr=4
her new daily
  • 3 weeks later...
her new daily
Same wheels as my M35... was waiting for a mate so i took a quick snap shot :)
  • 2 months later...
Hey guys, this is my R34 Skyline. Since I purchased it 5-6 months ago, I've done mostly cosmetic mods, like different lights, head unit, LED conversion. I have rims in the mail, which should arrive in 2-3 days. 18" PDW Replays. Let me know what you think! :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
