Hey Guys,
I am experiencing a pain in the ass water leak, the drivers side footwell is getting water in it... and not just a little dribble its enough to make the carpet in the lowest part of the well soaked. I have pluged up the rubber grommet on the firewall with enough silicon to sink a ship so im pretty certain its not coming in there. i had my windscreen replaced as i thought it may have been some kind of seal or issue with that (it also had a fair crack in it so needed replacing) but water is still coming in!! at the windscreen place the bloke reconed that it could be the roof bars as they can cause leaks easily he recons and that the water could be running down the A pillar and into the footwell?
If anyone has any ideas or has had a similar problem and can point me in the right direction please let me know
Thanks in advance :)
https://www.sau.com.au/forums/topic/224028-water-leak-drivers-side-footwell/
IN D/S mudguard, behind the liner there is a big rubber gromet that has umpteen wires going thru. Have a look there.
Could be some extra wires have been run thru and disturbed the seal.
Yeah there were a few wires going through there for various things but like i said i have siliconed the crap out of that so i don't think thats what it is.
The water doesn't smell dank straight away like if it sits there for a few days then it does get a bit. Water is only coming in when it is raining not at any other time? wouldn't water leak in all the time if it was a cracked heater core? i really don't know anything about that system. My heater works fine too as well as my aircon so it doesn't appear broken.
Blocked drain on the aircon? how do i get to that to clean it out?
Thanks for the input guys
Next time it rains, remove scuff plate, kick panel and lift up carpet. You should be able to see the direction it's coming from.
Or do the same and hit a carwash or garden hose.
Do Stags have a drain plug in the footwell, if so and it's missing or damaged you could be scooping water in as you drive.
Damn surprised it's not the heater core, almost always is with passenger side foot well puddles.
But as said you'd smell the coolant and if you drove a distance with the heater on your pudlle would be warm.
well im almost certain its not the heater core then... as the puddle doesn't get warm, and the longer i drive in the rain the more water comes in... i have lifted up the carpet and everything and not found any kind of plug... yeah i think on the weekend i might have to pull out as much of the carpet and kick pannel n go the hose n see if i can see something... if i still can't see anything off with the drivers side front wheel then the inner guards and have a good look there. Ill be sure to let u all know if i find something weird :thumbsup:
Cheers all
Well i caught the rain in the act this time!! it was actually raining all the way home this time not just the first 20 minutes then nothing until i got home!! ggrrrr#(i*$(& BUT ITS OKAY, as this time i got a light and stuck my head right up in there and yep... the big rubber firewall grommet was still leaking even after i (thought) i siloconed the crap out of it. Well this time i have pull the wheel off and the entire inner guard and really gave it a good smattering, lets hope (pray) that that is the only place the water was getting in and its sealed now.
Stick it on the hoist and see if there is water coming out?
Dumb idea, but Ive seen dumb things work. Like one of my new employee's for instance.
hahaha good call :( im just going to try pulling out as much shit as i can around the area on the weekend and getting someone to smash the car with a hose...
haa.. you just made me think of the scene from " the gods must be crazy " when some guy gets a bucket of water out to wash the windscreen of this old range rover.. only to chuck it at the windscreen to realise there is no glass in it.. totally drenching the occupant - ok - so its a " had to be there" moment
Get a high pressure (car lovers FTW) hose onto it, it will be represent driving in the rain. Water is very sneaky!
I Love that movie!!! i have both of em on DVD, can totally related. I wish my car was in africa at the moment, no rain would be a good thing, but instead im in Melbourne and it is for once raining every day, everyone else is happy... i seem to be the only one cursing it!! I am taking the car into Racepace on saturday as well so they will have it for a week. Guess ill just have to soak up the water try n find it AGAIN!!!!
  • 9 months later...
Sorry to drag this back up again but has anyone any ideas what the problem could be I've removed the roofrails and replaced them with the blanking strips so rain can't get in thru there I've also replaced and checked the heater core and siliconed up the grommet in the drivers side but still rain gets in.
Has anyone any ideas or had this problem fixed it's so driving me crazy!!
The only way to find a water leak is get a hose and spend 5-10 min on each section of the car and have some one in side waiting for the water to come
in, if go spraying it willy nilly you will never find it. Always work from the bottom first, eg firewall, doors, heater in take, windscreen and roof rails.
Spend an extra 5min pouring water in the heater in take, they are designed to have water going in but some times the drain clogs up and the water works it way through the ducting and into the car.
good luck, you will need it
there is a water stain on one of the hoses for my heater thingo up under the passenger side dash... no puddles though, so hoping it is just a hose issue, not the heater core... it is parked under cover so hard to tell.... will send it off to a mechanic soon i think
I just fixed our p/side water leak. Hope this fixes a few other peoples leaks. Lift bonnet, remove windscreen wipers, remove long black plastic scuttle panel held down by a heap of plastic clips. You will see a small plastic square (25mm?), light green fitting butted up to the bottom the windscreen on both sides (L&R). Remove both of those a replace the thin flat seal. Also there a couple of small black plastic fittings (about 25mm long that scuttle clips into) above heater?? inlet that need resealing aswell while you have car apart!! I just cut some thin double sided tape to fit. Then get back to Boosting!!
thanks will try that.
didn't even cross my mind that my car leaks till i seen this.
i always put it down to me riping out the plastic inner gaurds and it comming in through the bottom of a piller/firewall.
good job my amp is on the left side went through some huge puddles the other week and soaked the entire drivers side foot wells,didn't notice till it was sunny and my car stank, all the water was under the floor mats. took 2 weeks to dry
Mystag260 did you get to the bottom of yours what was it in the end?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
