Smoky had a go in it last night.......come on Smoky - what do you think?
You asked for it!! ;) My first impressions of the mighty white nuget:
Positives :)
Its pretty loud, so it drowns out Steveo and his sh!t talking
Its got some pretty decent power, so it makes up for Steveo and his driving
Its got really dark tints, so you cant be seen in the nugget with Steveo
Negatives :)
Not a RWD
The driver
Doesnt sound like an RB
The gay Vengaboys tracks on the playlist ;)
All in all I think this nugget is one of the better nuggets ive experienced power wise, once brakes and gearbox are sorted along with sponsorship from Bonds for all those little "acidents" this should be a pretty good setup ;) All the best Steveo, play it safe and enjoy!! :(
P.S. Our bet still stands Fagman!! :D
  • Replies 129
Posted Images
Well Steveo.
At least you can say all that patience has paid of.
It pays to spend a little bit more money on the best quality work and really get the best out of the end results.
It's good you finally have her just the way you planned. I am very happy for you.
And if you aren't happy I'm going to kick you for complaining! :)
Yeah dont worry guys, its booked for superlap, and 2 wakefield days already ;)
Its on the stock brakes still though for this weekend and the stock gearbox, so if i can do a 1.12 ill be happy considering it hasnt been thrashed for 2 years.
Here's a pic of 2 year old brake fluid, its now got new stuff in there:
Haha steveo - good times..
Those words have never been used in one sentence before.
:happy:
Yeah yeah....
Haha ohh shii, we'll have to meet up soon Steve, considering i wasn't home when you came around.
i want my pig back now!
Anytime! PM me whenever or come on saturday, if you come saturday bring your helmet :ermm:
how much are you planning to run?
26psi and new cams
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
