i don't know about east coast but heasmans have plenty of experience with GTRs and every other type of car.
which parts exactly did you get? if you have all the arms that means front lower control arms , front upper control arms , rear lower control arms but I didn't think ikeya make 34 GTR rear upper control arms?
I used Heasmans last week, Doug knew exactly what was what. Make sure Doug is the guy you speak to
Here's how they left my car for pickup (im always worried about where i park it) so i asked them to leave it somewhere safe, and they gave me this whole space
which ones? i got the the tracton rods and the camber arms and the lower A arms for the rear and the subframe pinapples, for the front i got the upper and lower and the upper link rods, i didnt get the tie rod ends so im hopeing they wont be needed when ajusting the roll center
Edited by NIS.26L
hmm...wonder if Heasmans could get me in for superlap!
Steve0 - what work did they do? a touch alignment or did they fit new parts?
I need some work done before superlap....otherwise I'll add suspension to my book of excuses for superlap lol
that's a bit rude to the rest of the staff there mate. i have no problem with anyone that works there so I don't know why you wouldn't use anyone other than doug? sure doug is great and has been doing alingments for probably longer than i've been alive but who do you think is training all their other staff???? I don't know how many times you've been there but I must have used them at least a dozen times over the years and never had bad job done by any of their staff. to imply that doug is the only guy who knows what he's doing is a bit strong considering guys like paul joyner are some of the most experienced people in aus for suspension set-up. just call them up, make an apointment and drop the car off, whoever works on it will be sure to do what you ask. :P
george, you will love the ikeya front lower control arms. they are awesome. the front castor rods are literally more than double the thickness of any factory or aftermarket rod I have seen. they are good value too at around the $700 dollar mark considerng you get lower arm, roll centre adjuster and castor rod for that.
Alignment and camber change
Wait a sec, you've got me all wrong - all the guys there do good work, but ive found its always best to speak with the boss :D
Doug has always done the work on my families cars (been there more than 20 times with 6 cars in the family), and he's very smart. Afterall, his dad was the founder of the place and from my experience the rest of the staff go to him when they have questions to ask. The reason i go there is that my dad recommended the place as he was mates with Dougs dad when Dougs dad ran the place, and ive been very happy with their work, as im sure all their customers are
Anyway, in short, use Heasmans :D
Heasmans are pretty good. I think Doug does all the alignments. The only problem i have had is that they aligned my car with worn tie rods. I think this was just an oversight tho as they said they always check them as a matter of course.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
