  • Replies 347
Well I am new to this site and I'm just passing by to say hi... This site rocks and so does my car....
Take care everybody :D ....Elle :)
hey Elle just a quick hello from the gold coast, have you done much work to your ride? and if so how quick? mine is still standard except 4 some bolt ons, but still damn fast 4 a street car. :headspin:
Tonight at WSID I beat my PB (14.46sec) and was relatively happy with the outcome. I did 4 pretty consistent runs but all feeling totally different behind the wheel. I had 2 goals at the beginning of the nite and didn't care which I got first. My 2 goals were 13.9sec ET or better and 100mph or better.
1) Didn't do much/any of a burnout just dropped it from 4,000rpm and let it spin for a metre to remove the water from the rear tyres. Used standard boost (7psi) and launched from 3000rpm. The entire 14.184sec felt like a Sunday drive, everything was perfectly smooth no wheelspin just perfect.
60ft: 2.168 (~3,000rpm)
MPH: 99.94
ET: 14.184sec
2) This time I switched it to 12psi to try and get abit more top end but resulted in axle tramp in the top of 1st gear and problems engaging 2nd gear.
60ft: 2.117 (~3,500rpm)
MPH: 98.66
ET: 14.383
3) Thought i'd use 7psi for first gear and then flick it to 12psi soon as I hit 2nd gear. Got my highest Mph but lost out from 1000ft -> 1320ft somehow even though I had a higher TS.
60ft: 2.098 (~4,000rpm)
MPH: 100.52
ET: 14.245
4) Bahh what a waste, too busy concentrating on the v8 beside me pulling away and I had a combination of axle tramp and missing 3rd gear.
60ft: 2.111 (~3,000rpm)
MPH: 94.70
ET: 14.702
Mods:
FMIC
K&N Panel Filter
3" Full exhaust
Bosch Fuel Pump
Daiken Clutch
7/12psi
I'm very happy with my 60ft times (Using 10,000km old 225/50/16 @ 38psi Michelin Preceda's). They were very consistent with no wheelspin at all. I need to tweak the rear suspension so i'll take a look at that this weekend and probably drop to ~20psi for next time just to try and get those 60ft times lower again.
Ben,
You can add my latest numbers to the list if you'd like. Cheers bud :D
ET - 12.870
MPH - 117.75
60ft - 2.476
ET - 12.847
MPH - 115.65
60 - 2.353
TYRES - RE540S
TRACTION - NONE!
NITTOS - NEED SOME :D
Nope.
Let the sh1tty crappy 99% dead tyres down to 11psi and fried 'em till they melted onto the tar... SLipped the clutch till it bit and it bit hard so i mashed the throttle and got all the way off the clutch... pics to come :)
Adrian
Hi every1
Im new here and hope to catch up with you all soon.
I've met Ben and Adrian at the last Street meet had a ball and ran a not bad time for my first time out.. (congrats on the 12.5 Adrian)
Ben can you add me to the list when ya ready mate
ET - 13.980
TS - 100.76
60ft 2.157
Bridgestone GRID II 255-40-17 @ 20PSI
BP 98 octane
you have the time slip on this one Ben :)
not fair, does it have to be on pulp, ill run it this week on optimax
LIES.
hey adrian got my new clutch, and it grips like a mother ***cer, ill be there on wednesday after i get some more fuel,wasted it all drivingto the wrkshop, hope to get another run next to you, and some more pics. i also think i should drop the pressure in my tires to about 11psi, 25 is way to much what i used last time.
Motion not to add nicknick's time until someone from SAU watches his fill up at the Shell at Eastern Creek before the drags :rofl: :rofl: :rofl:
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
