  • Replies 347
Well I am new to this site and I'm just passing by to say hi... This site rocks and so does my car....
Take care everybody :D ....Elle :)
hey Elle just a quick hello from the gold coast, have you done much work to your ride? and if so how quick? mine is still standard except 4 some bolt ons, but still damn fast 4 a street car. :headspin:
Tonight at WSID I beat my PB (14.46sec) and was relatively happy with the outcome. I did 4 pretty consistent runs but all feeling totally different behind the wheel. I had 2 goals at the beginning of the nite and didn't care which I got first. My 2 goals were 13.9sec ET or better and 100mph or better.
1) Didn't do much/any of a burnout just dropped it from 4,000rpm and let it spin for a metre to remove the water from the rear tyres. Used standard boost (7psi) and launched from 3000rpm. The entire 14.184sec felt like a Sunday drive, everything was perfectly smooth no wheelspin just perfect.
60ft: 2.168 (~3,000rpm)
MPH: 99.94
ET: 14.184sec
2) This time I switched it to 12psi to try and get abit more top end but resulted in axle tramp in the top of 1st gear and problems engaging 2nd gear.
60ft: 2.117 (~3,500rpm)
MPH: 98.66
ET: 14.383
3) Thought i'd use 7psi for first gear and then flick it to 12psi soon as I hit 2nd gear. Got my highest Mph but lost out from 1000ft -> 1320ft somehow even though I had a higher TS.
60ft: 2.098 (~4,000rpm)
MPH: 100.52
ET: 14.245
4) Bahh what a waste, too busy concentrating on the v8 beside me pulling away and I had a combination of axle tramp and missing 3rd gear.
60ft: 2.111 (~3,000rpm)
MPH: 94.70
ET: 14.702
Mods:
FMIC
K&N Panel Filter
3" Full exhaust
Bosch Fuel Pump
Daiken Clutch
7/12psi
I'm very happy with my 60ft times (Using 10,000km old 225/50/16 @ 38psi Michelin Preceda's). They were very consistent with no wheelspin at all. I need to tweak the rear suspension so i'll take a look at that this weekend and probably drop to ~20psi for next time just to try and get those 60ft times lower again.
Ben,
You can add my latest numbers to the list if you'd like. Cheers bud :D
ET - 12.870
MPH - 117.75
60ft - 2.476
ET - 12.847
MPH - 115.65
60 - 2.353
TYRES - RE540S
TRACTION - NONE!
NITTOS - NEED SOME :D
Nope.
Let the sh1tty crappy 99% dead tyres down to 11psi and fried 'em till they melted onto the tar... SLipped the clutch till it bit and it bit hard so i mashed the throttle and got all the way off the clutch... pics to come :)
Adrian
Hi every1
Im new here and hope to catch up with you all soon.
I've met Ben and Adrian at the last Street meet had a ball and ran a not bad time for my first time out.. (congrats on the 12.5 Adrian)
Ben can you add me to the list when ya ready mate
ET - 13.980
TS - 100.76
60ft 2.157
Bridgestone GRID II 255-40-17 @ 20PSI
BP 98 octane
you have the time slip on this one Ben :)
not fair, does it have to be on pulp, ill run it this week on optimax
LIES.
hey adrian got my new clutch, and it grips like a mother ***cer, ill be there on wednesday after i get some more fuel,wasted it all drivingto the wrkshop, hope to get another run next to you, and some more pics. i also think i should drop the pressure in my tires to about 11psi, 25 is way to much what i used last time.
Motion not to add nicknick's time until someone from SAU watches his fill up at the Shell at Eastern Creek before the drags :rofl: :rofl: :rofl:
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
