And how come my oil temp nevers goes above 70?
You mean after warmup and >20min driving, you got oil temp of 70'c? A normal engine after warmup need about 80-90'c oil temp to effectively burn off combustion by product/water that get's in the oil.
Anyway where did you live where temp drop to -40'c?
Ive got a HR31 with the older redtop motor, its got apparantly 100,000 on it but its probably more like 150, anyway it blows no smoke and has even compression all over the board so it's in good condition. Pretty much stock standard but it does get quite hot in summer (sits on half temp - should get a proper guage though)
Anyway I was thinking something fully synth 10-40 or should I go something thicker like 50w for summer?
Wow, they do have alot of brands there. How much is their Redline selling?
No idea but judging from their Delvac pricing it wont be cheap. :)
Oh well, I guess I'll have to fork out the money, unless there is something better than Delvac for 70 bucks? :P
No idea but judging from their Delvac pricing it wont be cheap. :dry:
Oh well, I guess I'll have to fork out the money, unless there is something better than Delvac for 70 bucks? :sleep:
Do check with Harold from performancelub.com they do supply Mobil, Royal Purple & some other stuffs.
hey trex and busky2k
I'm getting confused with the diff oil...read stuff about it and thought i was cool...
Castrol Syntrans and Syntrax..75W90 I think they are spec'd at. I have a stock s1 r33. I used Syntrax as it was GL5 rated oil...wondering if I should have used the Syntrans..I get confused with them..Its not for LSDs and I have no idea if I have one or not lol I guess I should know.
KJ
Castrol Syntrax 75W90 - GL4/5 suitable for both diffs and gearboxes.
Castrol Syntrans 75W85 - GL4 for gearboxes only but tends to give better shifting than Syntrax for gearboxes specifying GL4 fluids such as our nissans.
So you chose the right thing!
haha thanks man...it didn't make any noises...so I thought I was cool. Just in the Castrol spec sheet it says not for LSDs...but the stock R33 diff is a viscious LSD and aparently this is still cool...but I'm still not sure about that.
When an oil is spec'd for LSD use, they mean its appropriately friction modified for clutch LSDs. Most of our LSDs are viscous coupling (VLSD) which means they use their own internal fluid for the 'lockup'. So for VLSDs it doesn't matter if the oil is specifically rated for LSD use or not - just so long as its API GL5 rated. So you are safe with Syntrax.
I looked for hours and couldn't find the info. Bascially I had to reasearch VSLDs and how they work and found out exactly what you said...then got confused again! haha thanks for that mate.
hey guys im due for my first oil change since i bought my car.. engine has recently been rebuilt and has been run-in.. was wondering wot oil to use.. have read/heard good things bout redline and royal purple.. shud i also change my transmission oil as well.. if so which oil?
also my friend had tried putting a short shifter into my car a month ago and the plastic thing right at the end of the gearstick came lose and got lost inside.. does this affect anything as i was told it will get munched up.. shud trans oil change be done to try n flush out any bits?
i mainly use the car on weekends and short trips but no track work etc.. also i was interested in getting a tomei baffle kit.. how does it affect the oil or change things for the better??
cheers
nesh
Can someone please confirm if 20/60 is too thick for my r33? When i give it a bit the oil pressure rises to nearly 8. should i drop the oil and put in some thinner oil?
If all else being equal, oil pressure is inversely proportionate to flow rate, the higher the pressure the lower the flow. You are starving your engine of precious oil during startup and before oil temp is up to operation temp.
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
