And how come my oil temp nevers goes above 70?
You mean after warmup and >20min driving, you got oil temp of 70'c? A normal engine after warmup need about 80-90'c oil temp to effectively burn off combustion by product/water that get's in the oil.
Anyway where did you live where temp drop to -40'c?
Ive got a HR31 with the older redtop motor, its got apparantly 100,000 on it but its probably more like 150, anyway it blows no smoke and has even compression all over the board so it's in good condition. Pretty much stock standard but it does get quite hot in summer (sits on half temp - should get a proper guage though)
Anyway I was thinking something fully synth 10-40 or should I go something thicker like 50w for summer?
Wow, they do have alot of brands there. How much is their Redline selling?
No idea but judging from their Delvac pricing it wont be cheap. :)
Oh well, I guess I'll have to fork out the money, unless there is something better than Delvac for 70 bucks? :P
No idea but judging from their Delvac pricing it wont be cheap. :dry:
Oh well, I guess I'll have to fork out the money, unless there is something better than Delvac for 70 bucks? :sleep:
Do check with Harold from performancelub.com they do supply Mobil, Royal Purple & some other stuffs.
hey trex and busky2k
I'm getting confused with the diff oil...read stuff about it and thought i was cool...
Castrol Syntrans and Syntrax..75W90 I think they are spec'd at. I have a stock s1 r33. I used Syntrax as it was GL5 rated oil...wondering if I should have used the Syntrans..I get confused with them..Its not for LSDs and I have no idea if I have one or not lol I guess I should know.
KJ
Castrol Syntrax 75W90 - GL4/5 suitable for both diffs and gearboxes.
Castrol Syntrans 75W85 - GL4 for gearboxes only but tends to give better shifting than Syntrax for gearboxes specifying GL4 fluids such as our nissans.
So you chose the right thing!
haha thanks man...it didn't make any noises...so I thought I was cool. Just in the Castrol spec sheet it says not for LSDs...but the stock R33 diff is a viscious LSD and aparently this is still cool...but I'm still not sure about that.
When an oil is spec'd for LSD use, they mean its appropriately friction modified for clutch LSDs. Most of our LSDs are viscous coupling (VLSD) which means they use their own internal fluid for the 'lockup'. So for VLSDs it doesn't matter if the oil is specifically rated for LSD use or not - just so long as its API GL5 rated. So you are safe with Syntrax.
I looked for hours and couldn't find the info. Bascially I had to reasearch VSLDs and how they work and found out exactly what you said...then got confused again! haha thanks for that mate.
hey guys im due for my first oil change since i bought my car.. engine has recently been rebuilt and has been run-in.. was wondering wot oil to use.. have read/heard good things bout redline and royal purple.. shud i also change my transmission oil as well.. if so which oil?
also my friend had tried putting a short shifter into my car a month ago and the plastic thing right at the end of the gearstick came lose and got lost inside.. does this affect anything as i was told it will get munched up.. shud trans oil change be done to try n flush out any bits?
i mainly use the car on weekends and short trips but no track work etc.. also i was interested in getting a tomei baffle kit.. how does it affect the oil or change things for the better??
cheers
nesh
Can someone please confirm if 20/60 is too thick for my r33? When i give it a bit the oil pressure rises to nearly 8. should i drop the oil and put in some thinner oil?
If all else being equal, oil pressure is inversely proportionate to flow rate, the higher the pressure the lower the flow. You are starving your engine of precious oil during startup and before oil temp is up to operation temp.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
