Item: Bosch 040 500hp intank fuel pump with bracket and plug to fit R33
Age: new unused
Condition: great
Price: $120
To Fit: (What car) 33 maybe more
Contact: PM or post here
Item: Standard R33 turbo
Age: off a series 2 with 80 000kms
Condition: great no shaft play,
Price: $340
To Fit: (What car) whatever you like!
Item: R33 split dump/front pipe, mild steel mandrel bent
Age: used for about a year
Condition: great light usual marks
Price: $180
Item: SPEEDFLOW custom braided lines to suite GT30 turbos, have check all fittings do fit into a standard turbo, comes with all lines except for oil drain which is usually done in rubber hose anyway.
Age: 1 year - bought in another package with other parts but dont need the lines!
Condition: great
Price: $140...... worth about $100 each line to get made up
Item: TurboTech Boost controller
Age: sitting in a box for about a year, used for about 3 months untill I had an EBC installed
Condition: great
Price: $20
To Fit: (What car) only limited by your imagination!
Prices Negotiable will post at buyers expense
Edited by ThirtyThree
ill take the turbo tonight if you want, pm me your number and ill call to arange, if i cant get it by tommorrow night then im not interested as im changing my dump pipe tommorrow and i figure while im doing that....lol
pm sent
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
