Item: new RB26 N1 parts
Age: 2008 so 0
Condition: brand spankers
Price: various
To Fit: (What car) RB26 engines (and some bits fit RB20 and RB25 too)
Contact: me, by pm or post here
Comments:
Hi Guys,
I recently purchased 2 brand new R34 RB26 N1 Nur motors. These are the top of the line factory built RB26s you can buy and were fitted to the R34 N1 Nur editions. Both the engines I had dissambled from brand new at Prime Garage in japan and rebuilt with some even more upgraded parts. So I have the following bits for sale. They are all brand new and were removed from the crate motors without either motor ever doing a single revolution.
I have:
2 X full sets of RB26 N1 valve springs, these are a good idea if you are installing cams into your R32 or R33 RB26. nothing worse than old valve springs. a mechanic here in sydney recently tested these N1 springs against a set of tomei type A springs and tells me they are virtually identical. Price is $290 per set of 24. $10 postage for most of Aus. bargain valve spring upgrade.
2 X Brand new genuine Nissan timing belts. again, never been used, and genuine is always a good choice if you are doing a big service or cam upgrade on your RB26. The timing belt I understand also fits RB20 and RB25. Price = $100 each. $5 postage for most of Aus.
2 X sets of N1 cams. These are known as a great mild cam upgrade for use with turbos like N1s, garrett -5s and -7s and HKS GTSS or 2530. They have higher lift and longer duration than regular RB26 cams. Being genuine they are also better quality than some of the cheaper aftermarket options. These are direct bolt in to R34 RB26 but please check with your mechanic about fitting them to R32 and R33 RB26 (they may fit, or you may require the use of an R34 CAS). Price is $400 a pair postage I estimate at $25 for most of aus. Bargain cam upgrade! Many cluey workshops have been using N1 cams with good success for years now.
That's it for the moment. Pics to follow tomorrow or saturday.
Hey Richie,
Sorry to burst your bubble, but the 34N1 (Nur) cams are same lift, duration. L.C. as standard R34.
The R32/33 N1's had the exhaust L.C. retarded 5 degs but the lobes were the same.
However, they are still one of the best cam choices for RB26.
cheers.
thanks benno. :) I have never measured them, just going by what I was told in japan, and by a few workshops here. if they are the same it's weird as there is one workshop here in sydney who swears by "N1 cams". lol, he buys, and fits them and tells me they work very well with small turbos. in fact up to that point I had always thought they were the same too, but he convinced me.
edit: ahh, ok, just did some research. they are different to regular R32 and R33 cams. so still a good change for 32 or 33 RB26s and with some cam gears would be nice. but you are right, 34 GTR and 34 GTR N1 use the same cams. so no point for any 34 owners to buy them really. They can be used in RB20 too, but I have seen some pretty mixed results from RB20 with GTR cams.
anyway, considering all that, make the cams $350 a pair.
1 set of valve springs sold.
ok, price updates.
timing belts now $90 + $5 postage
Cams $360 inc postage
btw, 1 set of cams sold, 1 set of springs sold.
  • 3 weeks later...
sorry mate, no engines. :ermm:
price drop on the gear left.
R34 N1 valve springs $250 for a set, brand new.
R34 N1 cams, $250 a set brand new. good if you want to get a regrind, you can start with brand new cams.
Genuine nissan RB26/20/25 timing belts brand new, $80.
  • 2 months later...
Still got most of this stuff. completely forgot I had it till I tripped over the box. :P.
so to sumarise.
1 X Brand new R34 GTR N1 Nur Valve springs $250 for full in and ex set.
2 X Brand new R34 GTR N1 Nur Cams (in and ex). these can be cheaply reground into whatever you want and if going regrind it's good to start with brand new camshafts. note, to use on 32 or 33 I believe you need a 34 type CAS or some modding. check with your trusty mechanic. $250 per pair
2 X Brand new genuine Nissan RB timing belts, suit RB20, RB25 and RB26. perfect if you are nearing the 100,000km mark, or a good time to swap if you are fitting adjustable cam gears. these are top quality. :( $80 each. that is a bargain!
I have moved house now guys and this gear is clogging up the joint. do me a favour and buy something. :)
Hello Richard,
Those Valve springs fit a GTR33?
Have to ask.....even though I am 99%.
PM me if they do.
Thanks
Tekin..
Oh...can you build me an engine and send it too :bunny:
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
