As those of you who have noticed the link in my signature would already know, I'm in the business of t-shirt printing.
I've been in contact with Christian (Prank) over the last couple of weeks, discussing the possibility of producing a professionally printed Skylines Australia t-shirt.
I am aware that a few SAU t-shirts have been printed in the past for particular events, such as this year's Melbourne AutoSalon. However, as far as I know, most previous SAU t-shirt logos have been transfers - not intended to last any longer than the event itself.
The proposed SAU t-shirts will be professional printed on high quality t-shirts. Ie, these garments will be designed to last. Unfortunately, this also means we are effectively limited to one colour.
The proposed t-shirt design (rough diagram only) is as follows.
Across the back (black ink on white fabric, approx. 25cm in length):
A smaller version of this logo (without the URL) will also be printed across the front right side of the t-shirt (approx. 10-15cm in length).
Each t-shirt will sell for around $30.00. This figure includes postage (within Australia) as well as a $5.00 donation to SkylinesAustralia.com. This price is a ball-park figure only and could rise or fall slightly depending on a number of factors, such as order quantity.
So, what are your thoughts on this proposal and design? Would you be interested in purchasing a SAU t-shirt at around $30.00 (which includes a $5.00 donation to this forum)? Please express any interest and/or post any feedback/comments below.
To give you an idea of how the t-shirt will look, I have attached an image of a t-shirt previously printed by tshirttext. Obviously the colours and design will vary, but this will give you some indication. Click here.
David.
  • Replies 184
My preferred t-shirt wholesaler does not offer female fit t-shirts, but I could look elsewhere if you really wanted one.
Failing this, have a look at this sizing chart. A lot of girls who want a tighter fit simply opt for a smaller size.
Yes, I'd like to big up SAU by wearing a t-shirt over (up?) here in Japan.... any chance of dark blue/grey for us style concious blokes?:D
Is the design final or can we have a design thread for ppl to post their own designs then vote on the best? This is what we have done for the last 3 shirts I have printed for my other forum.
Either way....put me down for one. I'm just not a huge fan of the above design...too basic.
This shouldn't be a problem. Who else would prefer white ink on dark fabric? Long sleeve t-shirts will also be available, but will incur a surcharge of around $4.00.
I've never sent a t-shirt to Japan - any idea how long it would take and/or how much it would cost?
White print on black fabric would be nice (i'd prefer it too). White shirts get dirty too easy (or maybe thats just my bad habits).
A long sleeved shirt would be perfect for events such as drag strip and trackdays.
Put me down for atleast 1 shirt regardless of what they look like.
Originally posted by Grim
Is the design final or can we have a design thread for ppl to post their own designs then vote on the best? I'm just not a huge fan of the above design...too basic.
The design is relatively simple, yes. A second colour would increase the price of the t-shirt significantly. Keeping this in mind, feel free to post your own suggestions.
The final design must be replicated in a vector graphics program (before being transferred to a printing screen), so you will have to provide any fonts, etc., that you use.
Going by EMS postal rates, it should cost 600yen, or about A$7...
If you can send them to Japan, I'll pay whatever it costs. So pencil me in for 1x Dark blue with White logo, and 1x Medium Grey with Black logo. Cheers P1E!
hey guys - that above logo was just a simple suggested one by myself. We can only have text (i think, David?) - but feel free to submit any other designs that you think might work.
Christian
I think at the back side should have some graphics more than only texts, maybe just round shapes or else. A smaller version of the logo that you said it will be printed across the front right side of the t-shirt, this font looks not too bad and the URL would be or not, it's ok both.
waitin' for the final........
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
