i got another question guys... how much does it cost to install a power fc d jetro into an r32 gtr? my mechanic said he cant find something on the intake plenum and has to take the plenum out.. will take about 6-7 hours labour... this definitely does not seem right to me... anyone else know?i think he is looking for drill points or something?
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/
my mechanic first quoted 550, tuned, now it has gone up to 250-280 just for installation, then it went up again to 6-7 hours labour - $600-700 just to install... other places have quoted 600-800 installed and tuned... i dont know what the deal is
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3957508
In this case you should get the opinion of other mechanics (is you car still drivable?)
If they all quote around the same then you know your first mechanic is not telling fibs.
Sometimes mechanics charge you their "learning curve" time as they are not sure how to install.
Alternatively, why don't you consider DIY??
Check the link below:
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
Great credit to the author!!
There is a section on installation...
Once installed correctly, car will start with a base tune. You can then drive to a tuner and just pay tune time. Save you plenty $$$
Edited by im late
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3957848
Tommy,
I think this answers you question about issue with Plenum:
Extracted from: http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
How do I hook up the D-Jetro Map Sensor Harness Kit?
There are various installation methods for the Djetro Map Sensor depending on the Car Model.
This will depend on your car - it's recommended to view the documentation for your specific Djetro model. The manual will be in Japanese but the wiring should be in clear english with pinouts etc. Evo Lancer CT9A do not have to do anything as the car runs a factory Map Sensor.Skyline RB26 customers must splice twin Map sensor into the Airflow meter signal wires on the std ECU loom. Nissan S15 customers must also manually splice a single Map Sensor into the harness (via AFM signal wire)
Below are instructions on how Skyline RB26 customers should connect up the Djetro kit.
It appears that D-jetro customers must splice the twin map sensors into the Boost Control Kit harness (or at least use the same port) to extract positive and negative power.
The signal for each MAP sensor is then connected to each of the AFM input signals on the main ECU loom.
So Map sensor #1 which is located near Cylinder #3 on the intake plenum runs to AFM input #1 on the ECU loom.
and Map sensor #2 which is located near Cylnder #4 on the intake plenum runs to AFM input #2 on the ECU loom.
For a more in depth diagram and guide please view the correct manual for your car's Djetro version as it will have correct Map Sensor wiring.
Diagram is in the link above :P
I hope the helps clear things up.
Edited by im late
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3957860
plenum had to come off, and it definately takes time to do that with the engine still in the car, its a bit of a pain in the ass. Going to be doing to my lil bros gtr soon, but we are taking the engine out at the same time so it should be easier (upgrading turbo and clutch)
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3957879
Tommy,
Thanks for the link Adam, I've looked into this and im not much of a DIY person so id best leave it up to the experts.. ill call around tomorrow and see what prices other mechanics are charging.. i remember calling around before and the prices were around 600-1100(tuned), depending on the place i went to.. ill check again anyhow
Edited by Tomei_32
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3957902
^^^^ f**k that, your on drugs if you think you can catch even half.... i bench tested this idea in front of a customer years back (and i even tried a greased drill bit on the 2nd runner) and it still drops enough in to worry me.
http://www.skylinesaustralia.com/forums/Po...-3-t217875.html
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3961655
+1 to Trent's comment!!!!!!!!!!!!
It does not matter how good your mechanic thinks he is with the good old drill bit trick, It is a risky procedure.
Get it done properly the first time. Pay the labour to remove the plenum, don't risk it man. Do you think for one second the mechanic will gaurantee in writing that NO metal fragments will enter the motor and that he will pay for any damages caused if they do???? I don't think so...
The golden rule.....
Pay more now.. Pay less later.
:ermm:
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3961801
You guys seem to have a strong opinion against drilling it with the plenum in, I'd better do it the right way, whenever i skimp on costs, the golden always ALWAYS comes into play lol.. sounds like i better get it done right, lucky i asked :ermm: Thanks to Trent and Adam for the concern, could have been possible engine problems otherwise :)
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3961821
:PBJ:
You guys seem to have a strong opinion against drilling it with the plenum in, I'd better do it the right way, whenever i skimp on costs, the golden always ALWAYS comes into play lol.. sounds like i better get it done right, lucky i asked :) Thanks to Trent and Adam for the concern, could have been possible engine problems otherwise :)
My pleasure :)
It's great to see that you are going to do it properly. You will able to drive with confidence with your new ECU install. :ermm:
Edited by im late
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3961838
I have an r32 gtr with the d jectro pfc. My tuner just spliced 1 map sensor with the fuel pressure regulator line and the other into the bov line. It has never missed a beat.
I later changed the intake manifold gaskets with hks ones and at that time I decided to drill the holes and connect it as per the manual. I saw no difference. Me thinks the idling is worse than before. The nuts under the manifold took forever.
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3961999
so would it be ok to just hook the map sensors up to a vacuum port? not tap the manifold. i have a vacuum distrubition block on my brake booster line(its inline on the hose between the manifold and brake booster) i was planning on running each map sensor to each of its own ports. would that work? or do i really have to tap the manifold(frowns) its so hard to take off once the motors in the car.
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3962123
absolutely you are mad if you get a mechanic to drill and tap your manifold with it still attached to your head. you WILL get swarf in there and it will most likely damage your engine.
6-7hour is reasonable to remove and refit manifold, replace intake gaskets and throttle gaskets and drill and tap the two holes required.
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3964742
i presume xspeed or hyperdrive are doing the work, who do a lot of d-jetros? :)
hyperdrive are the ones that do the $800 install and tune package, but they dont remove the plenum, to remove the plenum ur looking at an extra $500 or so, thats what i was told.. heaps of people have had theirs installed with the plenum in, but i havent heard any problems.. if there were problems, i guess they wouldnt do it anymore?
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3965854
I've had my d-jetro map sensors coming off the balance tube too, just put a vacuum outlet in where the PCV used to be and then had a T piece split the signal to both sensors. At the time I thought it wasn't such a good idea, but I have since had the engine out and drilled and tapped as per the Apexi install instructions and notice NO difference to the way the car runs. I would spend <$20 on the parts to install via the T piece method and save the other cash for the tune.......
https://www.sau.com.au/forums/topic/224691-d-jetro-3233gtr/#findComment-3966841
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
