Chris (VZSS) - Was fun chasing you around the track.. was very very close by the end of the day!!! Hope to get a chance to beat you before I ship off or sell the car haha :)
haha..For sure mate...Chubbs is gonna let me know the next time he has OP or EC practice days on..So if its no Wakie, then masybe one of them..But it was fun watching you in my mirrors and seeing you there..lol..I reckon you have more in it though.. :D
  • Replies 221
Awesome day, as usual. Had some brake problems by the last session (i had none) and i got a broken windscreen but it was all worth it.
Did anyone catch my epic fail and recover on turn 1 on video, i want it sooooo bad, couldnt have done better if i tried
Thanks to all who organised, it was a very smoothly run event, now hurry up and do another one
Didn't catch it on video, but it was quite impressive. Just looked awesome!!!!!!!
Definitely get some hi temp fluid and decent pads.... I can't remember who but one of the 32's in Group 4 was having massive brake fade all day also....
yeah, should run quite a bit better... the ass was all over the shop to say the least, only able to put the power down in a straight line! .. Boost was wound down... but we did have the brakes/camber sorted... :D Still haven't added the last 10psi to the tune yet either. Started out at 16psi in the beginning of the day, think it was down to 12psi by the end of day trying to get some exit speed :D
All in all it was a great learning day for the car... and Daves dorifto skills !!!
Sorry to the guys in Group 4 about the brake fade, could only stick it to you guys for 1 or 2 laps and then I was on the floor!!!!!! Car was only on the road a week before, still needs a lot to sort. Will hopefully give you guys hell next time and hope to see you all at Texi 2 :)
yeah little bit more practice for me would be good... need a little more power for the straight though :) everyone pulled away from me on the straight but i was going well through the corners
haha..awww :D
At least you are going well through the corners and getting your lines right..That the part that needs the most work on the track
Thanks to everyone for an awesome day! Was the smoothest run track day i've been to and good to see everyone going out and giving it their best, but also using their heads and not causing many delays! I had an awesome day, managed to set a new PB of 1:14.8 which i'm stoked with considering the car is completely stock! Also managed to chew out a rear brake pad and hence probably written off the rotor, i have a nice grinding noise from the left rear when i brake now, but all worth it!
Great to catch up with all the familiar faces and some new ones! I'm flying back to WA on monday, so time to tuck the car away again :D, tell me if there are any events that people know of in Sep!
kbai
oh ps. more pics and video already! I've got some onboard footage, with some good shots of other cars on the track, but waiting for Greg to get them off the camera :)
BAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHA ROFLBURGER WITH LOLCHEESE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!111
Chubbs, where do you come up with this crap? LOLCHEESE??? WTF!!! :)
Have you been drinking again??
one more for shitsngiggles..
Anna or Dave, whoever was driving, the aftermath of that was very impressive! wish I had actually watched it happen hahaha.
here is the pic i took for you guys on the way home, showing where some mud was still found :D
http://i127.photobucket.com/albums/p122/Sl...83/IMG_5861.jpg
Almost had you in the last session Ian :D
You almost had me? You never had me - you never had your car... Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake! You almost had me?
Diesel-V.JPG:rofl::P:D
first time on the track, and i've found out why lots of track cars don't have sun roofs, can't sit properly with a helmet on :D head kept hitting the roof.
also a big thanks to reece (turismo) for showing me the lines and taking me out in his car, 1 word, awesome. now to figure out whats wrong with my brakes and seating position and i'll be out there again!!!
ok got a few pics... none actually at the track though...doh!
Friday night.....
Starting....
Getting there.....
post-30020-1214133184_thumb.jpg post-30020-1214133387_thumb.jpg post-30020-1214133675_thumb.jpg
Team spesh :D
After dinner.....
Dave realising that the dori dori slide had some downsides!!! Like cleaning the car!!
This was just the engine bay!
And then at the car wash this afternoon...
post-30020-1214134510_thumb.jpg post-30020-1214134810_thumb.jpg post-30020-1214135000_thumb.jpg
Finally clean again!!
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
