its a sticker isnt it?
just peel it off then give it a clean.
yeah i know its a sticker, but its way to hard to peel it off.. Besides, i bite my nails so its a lil bit hard to get under there..
If it's sticker then just peel it off then wipe the area with Metho on a soft rag.
i tried metho on my mates pulsar once, the paint around that area ended up a lil bit dull.. don think i wanna experiment on my car.. lol
Put a GTR badge over it
lol.. i don wanna attract attention, besides id rather the car look like a sleeper but go like a mother f%@#er..
where'd you get the cartoon picture ^^^ of the skyline from??
Metho is good. I would say the dullness would of come from scratching with your rag...
didnt your mother tel lyou not to bite your nails??
if your to scared to give it a go pay someone to do it. Trial and error is the only way to get things done if you dont want to pay money to get it done.
if you stuff it you know what not to do next time. :laugh:
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
