  • Replies 129
some lucky ppl then =P
Do they have bulbs for the boot light and interior globes? I'm pretty sure the globe in the boot is the standard parker type globes. If they can do those and the interior globes as LEDs I'd be interested :rofl:
Also did the HIDs get sent out with Aust Post or courier? Just wondering...I keep ducking out to the store room at work to see if they've arrived lol
aus post, i have one set of LED wedge parkers left, for $15 + 2.50 for postage, you could prob use those as the boot light, ill find out about the interior for you later on today
No worries, I'll wait on confirmation for interior lights, otherwise I might just mount a Neon light in the boot running of the 12v boot light power and ditch the bulb.
Cheers
Well I just received an sms from my brother saying a package has arrived for me.
Not 100% sure if it is lights, but I hope so. Am bloody keen to put them in car!!! Aarrggghhhh
You might be in luck! Mine turned up this morning :D I'm hoping to get them in after work today :P
That is the annoying thing though, I am leaving straight from work to get on plane at 750 to go to perth till Saturday night.
So I cant check till sunday...lol
Ah well, I will live..
Post up some pics here once you get them in :)
thanks WKD! Yeah will do! If not this arvo, maybe on the weekend I might get around to fitting them. Works been busy as with a system migration in progress so overtime might eat into installing HID time :P I don't want to do a rush job of it :D
indeed they were,
just one thing on installing, make sure that when you plug the balast in the plug is the right way, if it isnt you will blow the globe and that isnt covered under warranty
hey guys, just so you all know, the kits pictured here are not the Cosnica Kits, theyre the kits offered by Matt Tuckett from Angry Industries. the kits WKD-031 is selling are different. The images are lifted directly from Matt's sale threads on the R31 Skyline Club Forums, and all the cars pictured are using his kits. hope this helps.
garrrr tis true, the origional pics and info were used from angrys post, but this forum doesnt alow me to put up the pics of my HIDs once they were installed, hence the follow up pics, and i assure you that the HID kits that were supplied are cosnica kits, and further more i had the permision to use some of the pictures supplyed on the first post
Right this is bullshit... Wasn't gonna say anything on R31 club BUT....
Get ur own f**kin idea man. Seriously. Stealing someone elses idea for a sale, stealing their pics, their product... Whats next... U gonna take his woman? f**kin low man! I love ur quote.... "I dont wanna cut his grass... My prices r cheaper"... I hate people like this!
He wasn't even in the country when you started. After 5 successful group buys on R31 club, he goes on holiday and u jump in on the same product.... LOL... Too bad he already exhausted R31 club b4 u got to it.. Can't believe u even tried man. Pretty pathetic.
For all those thinking of buying HID kits... Angry is a trusted member of both clubs... 7 or 8 group buys on 31 club, maybe 9 and not a single thing gone wrong with money OR product quality or anything for that matter. There is about 70 or 80 ppl who will back that up.
Find something else to sell man!
EAT A BAG!!! :D
Good luck :rolleyes:
Edited by FordyR31
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
