Not necessarily. The KA24DE saw duty in the US-delivered Silvia in a longtitudinal mount.
I'm pretty sure old-school Pintaras are RWD - my mate had a TRX with an FJ20 - and I don't think anyone makes an FR with a latitudinally mounted engine.
Edited by scathing
After looking at pictures of the Pintara and Bluebird, yeah I probably am thinking of the Bluebird TRX.
And according to Wikipedia, the KA24DE powered Pintara was FWD. SR20 is the only reasonably feasible option, I'm afraid.
SR20 > RB20 anyway :flamesuit-on:
you could possibly get the SR20DE out of the pulsar and thwack it in...
the KA24DE did come out in u13 bluebirds, and is quite a popular donk, and has been transplanted into a few U12 Pintaras + Turbo'd
CA18DE/T is another option - (from the EXA)
Rb20 = NO.
I presume in saying KA24 you've got a U12
head over to www.antrx.com and see what they've got going on.
Edited by B. J.
make sure you add the right stickers and autobarn washer nozzles and chrome hubcaps...
oh and its GOT to have the throwover seat covers.
nightshades
5 inch cannon
and go to antrx.com.......
read for about 3 days.
dont post anything, just search & read.
the bottom line is:
SR20det fits,
need a SR20de gearbox from N14/15 pulsar
OR get a KA24e 5 speed manual, get the SR bellhousing bolted to that (with a 4 minute grind job)
need bluebird engine mounts or custom
need pulsar driveshafts & cv joints, possible custom
new exh
new loom
The Pintara with the KA24 is a FWD. So, the KA24 is the E-W version. It superseded the R31 Pintara, which was RWD.
surely the SR20DET out of the u13 bluebird would fit.. east-west mounted DET and will fit anywhere an east-west mounted DE will fit...
Would probably pull about 147fwkw out of it with a decent install...
The other engine you could swap out for (prolly harder to find) is the SR20DE VVL (not sure on engine number).. i think it comes in one series of xtrail... nice motor and will give you more power than a normal DE.. close to DET performance in standard form i believe
edit: ok i did a bit more research.. the VVL version of SR20 is called SR20VE.. There is also a SR20VET version of this engine which is said to have come out of the factory at 280ps (206kw) although this engine may have been mounted N/S but i cant find info on this..
The SR20VE is good for about 136kw
Keeping in mind the a standard SR20DE is good for about 105kw at flywheel.
Edited by nitestalkr
SR20VET is found in the X-Trail, so its also a latitudinally mounted engine.
A GTiR's SR20DET (with the quad throttles) makes more power, stock, than the U13's SR20DET. I think the blocks are stronger and the GTiR uses a T28 to the U13's T25, as well. It should be cheaper than the SR20VET, and will certainly be easier to find in Australia.
Edited by scathing
The GTiR's SR20 does make more power and torque than the u13's.. problem is they are a bitch to mount E/W and to transfer from 4wd to 2wd.. people used to try it in pulsars (N14&15), but most people took the easier (and i dare say cheaper) route of the u13 SR...
Something i would like to see would be how many of the components from the GTiR version would bolt up to the others.. quad throttles etc..
A forum that i used to be a member of would prolly have more info on E/W mounted engines and value for money options.. www.pulsar.org.au
If the forum hasn't gone to the trolls yet, it should have some decent info..
Interesting the turbo flanges differ though... didnt know that.
umm GTI-R SR20s are mounted east-west standard.... and it's pretty much a front drive set up too, just with a transfer case off the back of the box sending power to the rear. after all GTI-R is based on an N14 front wheel drive platform, just with awd added.
oh, and it has lots of advantages over the other versions of SR20. it has solid lifters, bigger cams, better springs, better head, quad throttles, piston oil squirters in the block, bigger T28 steel wheel turbo (that can handle serious boost), different block, different crank (wider conrods and conrod bearings too), some say better pistons too. that's all I can think of off the top of my head.
Bingo, also rebadged as a Ford Corsair..
the baron of beer is correct.
a friend was trying to pop his as he had another engine and turbo setup ready to go in.
AVCR peak hold showed 1.9Bar
Apexi RSM peak hold also showed 9765rpm.
Didn't pop.
rb20 does fit in a pinntara as i was in one last night..hes got a silvertop in it but i think the rb20 is from a ceferio
That would have been an R31 pintara, not a U12 pintara.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
