  • Replies 45
Umm, guys, just thought I'd say something, the original manifold keeps being referred to as "stock extractors". They aren't, the original one is just a cast iron exhaust manifold. Extractors are as the Coby ones- e.g tubular, better flow than stock. Actualy, "Tube Headers" is more accurate as a term, as extractors are really only a particular design of tubular headers which act to "extract" gas from the cylinder by clever use of cylinder pulses.
cheers,
floody
  • 4 weeks later...
hey guys, i've finally fitted the coby extractors on the car. cost $99. car is much more responsive from around 2500 rpm. i've ended up taking the pod filter off and putting the stock box on with trust panel filter, the sound is soo lound with the pod on!
only prob i have now is that for some reason it hangs low like dogs balls and scrapes on my driveway :P not sure which part exactly is scraping, i suspect its the part where it bends. gotta get outta the car and have a proper look.
hey denny,
its weird, my fuel economy slightly improved?! the extractors do hang quite low don't they, it makes me reluctant to lower my car.
i will organise that dyno day we spoke about as soon as i finish my exams (november 10) so a few of us n/a guys can compare numbers and not feel uncomfortable about the big numbers the turbos pull :( is there anything to 'tune' on a standard skyline? i was told u need at least SAFC or something before dyno tuning is worthwhile?
cheers
greg
hey greg, with a standard skyline i guess all they can do is advance the ignition timing. i've actually got the old school generation 1 safc, the one with the knobs on it lol. theres only like 5 tuning points though. i picked it up really cheap so thought might as well give it a try. anyone else got ? u can turn it up -30 or +30, i take it when u go towards minus thats leaning it out?
only prob i have now is that for some reason it hangs low like dogs balls and scrapes on my driveway :)  not sure which part exactly is scraping, i suspect its the part where it bends.  gotta get outta the car and have a proper look.
they only cost $99?? what the fudge?
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
