hi guys i got my fuel pump and pressure reg delivered today. something else came in the box which im not quite sure about. it came in a genuine nissan box and has "A VALVE CUT" on it. i am yet to pull my pump out so im not sure where it goes or what it does. it is in the picture on the bottom right.
https://www.sau.com.au/forums/topic/225807-fuel-pump/
Not positive but could be the fuel valve (in red on pic) , fits on the pump outlet hose inside the tank, you should see it when you pull your old on out. What did you buy and from where ? looks like a Skyline pump assembly.
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-3976856
http://www.skylinesaustralia.com/forums/Fu...mp;hl=fuel+pump
completely different, although basic pump may be the same, which is all you needed, wiring is also diffferent. may be a challenge.
I ended up getting a SARD universal, direct drop-in replacement for the Stagea pump
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-3976897
well positive and negative is all the same regardless with wiring so that wont be hard to overcome shoudln't be to hard to get the pump into the stag bracket. so with any luck i will make it work. cant complain for $300 all up.
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-3976905
hey chook, i to have the sard fuel pump but i had some problems with its dual flow rates..the idol flow rate makes the stag have a flat spot on takking off from a standing start.. did u have this problem? the auto spark is going to earth the pump so it runs at 100 percent all the time
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-3977243
  • 4 months later...
Hi guys, anyone installed a Walbro GSS342? It's 255LPH/500hp pretty similar spec's to bosch 040, and is also an in-tank pump... workshop recommended them over the Bosch; apparently the feedback they have had is that they are quieter than the 040 and very easy to fit. Just wondering if anyone's fitted one themselves to a series 2 stagea? How easy is it?
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-4249291
  • 9 months later...
Sorry for waking up an old thread, but if you're fitting a 040 pump how much do you fuel-proof the wiring to the pump? Are the rubber boots enough. I notice the stock pump has the plugs, but no real protection against the fuel.
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-4764652
  • 4 months later...
Did you find out anything in the end Ruby? I just got a 040 replacement for my 12-month-old Walbro (which died :rant:) and could do with some advice on how to get it into the bracket - it's frickin huge compared to the GSS-342 Walbro!
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-5000237
there is a photo on here somewhere of a 040 mounted on a stagea bracket . yeah its big but it fits well. i am not a fan of wallbros really . if something is smaller then it is doing more work and going to wear faster than something twice the size doing the same amount of work . and it would be twice as hard to make to the same standard so it should cost twice as much but it doesnt so yeah .
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-5003132
Hey that's interesting, thanks Lachlan. Didn't find that one! Just what I was after.
However ditching the cradle completely like that means no direct supply of fuel to the pump when the inch or two that's left in the bottom of the tank runs away during a corner... and I thought that pump had been designed to mount vertically? The pickup covers the whole end; so as the fuel level begins to drop a lot of it will become exposed...
Sold my 040 now but having a fuel pump die on you is still a little concerning... had a bit of a hassle starting it again tonight, after only about its 3rd real run since changing the pump. Not sure if it was still bleeding air out or I had bad fuel or what.
https://www.sau.com.au/forums/topic/225807-fuel-pump/#findComment-5003885
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
