Hi ppl.
well i was driving today for about 10 mins the HICAS light comes on,i turned the car off then on and it's gone,drive for another 10mins it's back on again.does any one know why it does that?help plz ppl its annoying.cheers
check your power steering fluid. when it gets low it'll turn the light on
https://www.sau.com.au/forums/topic/225808-hicas/#findComment-3976835
Hi ppl.
did the steering become tighter, and did re-alignment of the steering wheel and hicas sensor resolve your issuE?
https://www.sau.com.au/forums/topic/225808-hicas/#findComment-3992931
Check All fluids... So Power Steering / HICAS Fuild
Any of you had new tyres and a Wheel alignment done lately?
If so,
Get your mechanics to check the alignement again
Then check the steering wheel sensor. Clean the sensor to get rid of any dirt / dust / grease and re-align the sensor back to the original position was it was when you take it out.
Then ask them to run a Diagnostics (Plug Diagnoistics Computer in) to check all the Sensors
The Diagnostics can give a reading of the steering sensor
For Example, Half a turn to the right = 180 degrees / Full turn to the right = 360 degrees.
If the Diagnostics does not read like that then it could be a Tyre / Caster rod issue. The rods could be out of alignment and need to be re-adjusted.
Re-align the Rods to match the Sensor to 0.
This happened to me and problem was fixed after this procedure.
It took atleast a day or so just fine adjusting the rods to get it exact reading.
https://www.sau.com.au/forums/topic/225808-hicas/#findComment-3994879
If so,
Hi mate, very interesting, never heard of this before,,,
since, i never had any problem with my hicas but after i changed front castor rods (adjust.) the hicas light started to come on after i drove over 80kms/hr then, i went back to get the wheels alignement done (4 wheels) and the problem still there!!
by the way, where can i get this done/check? i don't think where i've got my alignement done, there have the Diagnoistics tool! where steering is wheel sensor and how to get it cleaned??
cheers
Ford
https://www.sau.com.au/forums/topic/225808-hicas/#findComment-4003437
cheers
Ford
Hey Subie!
To get to the Steering Wheel Sensor, you have to take the steering wheel off and there should be a circular disk or plate, that is the sensor.
Unplug it and give it a clean (BUT before taking it out, mark a texture on it so you know you will place it back in the correct spot.
To clean it, my mechanic used an air gun and I think he sprayed some WD 40, gave it a good flush then placed it back in the correct spot. It gets rid of the dust and dirt.
Before I cleaned the sensor, my HICAS light would come on as soon as you start to turn left, like half a turn. After cleaing it it did not come on till ONE FULL LOCK to the LEFT.
Thats when he plugged in the Diagnostics computer. It can pick up all the sensors the car has, so we could isolate where the problem was. The mechanic should have the diagnositcs computer, unless you got one which probley set you back $6000 LOL!
As I said it was the rods that need alignment / adjustment.
Anyway I got 2 mechanics. The one who fixed my HICAS problem was a family friend of mine, Jansen who works at TGS Performance
18 Bricker St
Cheltenham, Victoria
3192
Melways Reference
Page 78 - B10
Phone: (03) 9555-0699
and my other mechanic is Shane at Le Mans Automotive
15 Websters Rd
Templestowe VIC 3106
Phone: (03) 9846 2761
If you are near these areas I suggest you take it to them, unless your HICAS is fixed... Or take it back to your mechanic...
I was not there when Jansen fix the problem so I didnt get to see exactly how he fixed it but this is pretty much what I was told.
But let me know how you go and I can ask for you and get some idea.
Cool!
https://www.sau.com.au/forums/topic/225808-hicas/#findComment-4003546
thanks for the reply mate,,, but unfortunately I'm in NSW otherwise i'll take it to one of ur mechanic..
i'll talk to my mechanic here and see what he can do
cheers
Ah damn! LOL!
Yeah I guess just mention to him the Steering Wheel Sensor, re-adjust the rods and diganose the car.
All the best!
https://www.sau.com.au/forums/topic/225808-hicas/#findComment-4004147
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
