  • Replies 78
nah everyones cool spanna anna!!
just bring your happy smiley self and she'll be right!
there isnt much to do to my car, turn up, unload it, drive it, pack it up and go home lols
hahaha okies.. you swinging past mine on the Sat morning???
I have the almighty tyre pressure guage.... il be your tyre pressure bitch :D
Actually, now that I think of it Spanna....
gimmie your brakes, wheels, turbo......etc etc :D
Richard, so what ya going to do mate!?!
bring ole S13 out!!
hmmmz.... NO!!!! :laugh:
Could do it in race tape ???? hehehehe
RIP LEE? :sick:
bring ole S13 out!!
I'll lend you my brakes, wheels, turbo......ect ect. :D I'll lend you my Subaru even! Its got the Subaru racing knock AKA some bearing that didn't get enough oil at some point. AND it has a hectic 100kWs!!! At the FLYWHEEL!!!
We meeting up somewhere before hand? Or just at OP at... 7ish... lolz
I'm there taking pics I'll come and see what everyones driving so I know what pics to get. get at least one of everyone plus video. might even put the camera in some cars for you guys
Cheers scotty
Edited by motoractionservices
I'll be there spectating, should be great fun :sick:
Anyone got a spare parking pass? Happy to pay, just not so keen on leaving my car in a spectator car park a fair way from the event (based off the number of people going, I don't imagine we can just park behind the pits as per normal?)
Cheers,
Tommo :D
Yo dude you want to borrow the camera mount?
I'll be there spectating, should be great fun :D
Cheers,
Tommo :P
Come say hello ya carnt.
Oh and yeah parking is crap if you get stuck over on the side where they rally in the dirt :whistling:
Cover's your car in red dirt if the wind is blowing in the parking direction.
I'll drop in and say hi if i can make it out. I can also offer nonsensical advice which, if you can under stand it, may knock milliseconds off your times, along with my usual "more boost, harden the fu(k up, and brake later then you really should"
I'm working in the morning but will try and get away as early as possible and make it to the track (seeing as it's only 15 minutes away)
Baron. s13 ftw, though what turbo is on it? looks like more boost is needed :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
