B-Man, yes there was a vulnerability in the windows operating system. However the the vulnerability was hacked by someone who decided to exploit it to send a worm around the net. Now had this person not intentionally created a program to exploit this vulnerability then everything would be fine.
I don't believe Microsoft are to be held accountable for what happened. It happened because some idiot decided to be a prick. The only person responsible for shit network performance due to packet loss is the person who wrote this worm. I have also recently been made aware that Microsoft did have a patch available to cure this vulnerablility (although I am reserving my judgement on the accuracy of this info). So therefore in my mind they found a problem and supplied a solution to it. I'll bet money on the fact that not 1 person I took a call from about this issue applied that patch.
  • Replies 52
The patch was actually available quite abit before this worm made its appearance (I believe around 2 mths earlier).
But then again how many people even know how to switch off their PC correctly let alone logon to WindowsUpdate.com
No. But thats Microsoft for you !
So do you agree that it is unfair ?
I just think commercial operating systems should quality control their products better - MS are making quillions so they should be able to afford too. The vulerability was Microsoft's problem in the first place in my mind - had it not been there - No Blaster. Simple as that in my mind. I know all software vendors release product with bugs - but I reckon they should test it better before they release it - Not Linux and GPL software cause no-one makes $$ out of that the same way MS, Oracle, Peoplesoft, SAP, etc make money.
Imagine if SAP had a bug in their payroll module - then some shmuck decides to exploit it because he's pissed with his brother-in-law or whatever. And becasue of the exploit - no one gets paid for 2 months while SAP write and distribute the patch - That woiuld be un-acceptable right ? SAP's fault right ?
Software is software - you pay for a product - It should work.
That's only my view of course - And I do tend to wear rose coloured glasses looking at the perfect world out there - Cause I am pretty perfect myself, NOT.
Cheers
:cool:
Yes I agree its unfair but nothing will be changed to fix the problem.
When you pay for this product... then take it home.... remove it from the plastic... rip through the T&C's that state that no responsibility will be take for blah blah blah you have just laid the blame on yourself for anything that goes wrong.
Yes I know - and that's not fair either - All care and no responsibility.
I know I'm discussing this pointlessly - Everyone just accepts it - However, if we all didn't just accept the situation - the software vendors would do different - IMHO.
yeah, no doubt that levels of issues in software would never be tolerated in other industries....
...but in this case, the vendor has supplied a fix for their problem before some l337 haxor created the worm, they've done their bit by making the fix available to all licensed owners for no charge.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
