Hey guys here are the engine specs
Arias rb30/26 conversion pistons
PAR conrods
All ARP bolts (head/mains/rods/exhaust manafold)
High energy 8.5lt oil sump
Jun oilpump
RB26 head Ported
Garret GT3582R turbo
870cc injectors
I am now about to make a choice on cams for it. I would like some advice from anyone else that has done it. Please let me know.
Im chasing a little more power but the car is used for drift so its not a drag car.
https://www.sau.com.au/forums/topic/226152-cam-shaft-choice-for-rb3026/
  • Replies 48
The answer on duration depends on what RPM range you are targetting, be realistic. If you intend to use 7,000 to 9,500 rpm, something around 272 to 288 degrees would be the go. For 5,500 to 8,000 rpm, around 260 to 272 and for 4,500 to 7,500 rpm then 248 to 260 is the go. That's a simplification, but you get the idea. As for lift, once I know the effective rpm range, I then choose the highest lift I can for that duration. What valve springs you are using will also determine the maximum lift.
Cheers
Gary
Drift...
As much lift as possible. 10-11mm lift and 265-272duration depending. 380-390rwkw without too much trouble with the .82.
Lift is the key. Duration simply drops the peak power roughly where you want it.
Expect it to cam over and sound extremely nice with 272's. :D
I've just came off the dyno with mine.. RB25 hydraulic head though.
Tighe cam regrinds 265in 263exh 9mm lift 221deg at 0.050".
200rwkw at 3500rpm and 256rwkw at 4000rpm @ 19psi boost then tails off quickly to 17psi where it makes 302rwkw at 6000rpm.
The cams have lost absolutely nothing down low its picked up power everywhere with its std centrelines inlet 110 LCA, Exhaust 115 LCA 112.5 LSA which = around 4-5degree's overlap.
Have yet to play with adj cam gears.
We had a few issues pushing more boost in.. It simply would not boost any more than 17psi over 5000rpm. Suspected a combination of the 1bar crappy Garrett actuator + 2" FMIC piping with a small 450x300 fmic.
RB26 cams from memory are around 236 duration with ~8.5mm lift.
In short.. RB30's definitely respond to Cams. :)
As its only running 4-5degree's overlap the idle is smooth. Its deeper and overall the exhaust is deeper and more throbby sounding.
Definitely doesn't sound like a regular rb20 or 25det.
Push in 5degree's advance to the inlet and it will lope like buggery. :D
I am running 20degree's static ignition which helps smooth idle when running bigger cams.
Generally richer afr's + more ignition timing will smooth an idle.
Leaner afr's and less ignition timing and it will lope.
But with mine.. ~5degree's overlap regardless if its running retarded or lean afr's it still idles smooth.
Hi Cubes , I asked in another thread about your cams but you may come here first .
From memory you used an R32 RB25DE hydraulic head so are the LCA's native to that engines cams or all RB25 cams ie 33 25DET cams ?
Very interested in these grinds - if they'll work in a 33 25DET engine .
Cheers A .
What are the pro's and cons of a regrind compared to a whole new billet cam?
What was the max size wise you could also go Cubes? Have been pondering a regrind of the cams i have in my engine.
I believe there is an 806C grind. Not sure on its specifics but thats where it ends.
More than a 265 duration and 9mm lift and you need valve springs, you'll need to machine the buckets.
Rip the head off spend $300 on a set of valve springs, machine the buckets and drop in a set of 10.5mm lift cams. :rofl:
I probably wouldn't bother regrinding a set of pon cams as you can still fetch good $$ for them s/h and then put a few hundred towards a new set imported from nengun or the likes.
A set of cams from Nengun are worth 800 odd delivered depending on brand.
Cheers for the reply.
Ive already got some Performance Springs Valve Springs in there so they should do the trick, however have never heard anything about machining the buckets? What needs to be done here?
Can you also elaborate on LCA's. Ive never really looked into cams as i havent got my machine running yet, however need to start doing some research now as im almost there.
Edited by SirRacer
Increased lift allows more power to be made at a given rev range.
Duration moves peak power higher up the rev range.
Really depends how hard you want to rev the 30. SK's recommendations are on the money.
I went for a 265 duration as Boostworx has had good results with them on the 30's with stock manifolds previously.
If you are running a nice inlet and exhaust smaller 256-260 cams will get you to 7.5-8k easily. Then tweak the inlet lca to move peak power around to where you want it.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
