Thanks for the kind words:D I was pretty impressed with the BOV too esp as I was expecting the usual rubber pipe.
The other thing that really impressed the hell out of me was the 100mm - 80mm air pipe to the turbo, all hand crafted. Also all the bends are steampipe and been blended so well they look like mandrel bends.
Evan truley does magic work, and as usual the photos just dont do it justice.
Had a bit of a chat to him about a new plenum - probably 3-4 weeks until he has finished making them and another week to go through fitting and testing.
https://www.sau.com.au/forums/topic/22635-car-photos/#findComment-485949
Cheers guys.
Paul would be good to see the photos of your baby once shes done:)
Well hippy I got a Signal sticker in the garage, only prob is I dont have any signal bits. Lots of HKS bits on the car and waiting to go on the car, just no HKS sticker - spose I'll have to get one before I wind in too much boost:D
Car is now getting tuned, unfortunately my little boy is still sick, so I cant be there. Cant wait, even with out a tune the car seems soooo much more responsive off boost, and the note is awesome, nice growl, even at idle sounds a bit angry.
https://www.sau.com.au/forums/topic/22635-car-photos/#findComment-486613
Thanks Dean, I am using a 40mm HKS standard wastegate, hope its big enough, its rated to over 500hp, so should be ok.
I will get a rwkw figure, but it will be no where near 300. The plenum has me a bit concerned, so I asked them to please just do a really safe tune, and keep the AF ratios on the conservative side. When the plenum has been upgraded, I will be doing head gasket and cams then start winding in the boost and see how close she gets to 300:)
https://www.sau.com.au/forums/topic/22635-car-photos/#findComment-486656
Hi Steve, nice car!! ;) Very nice pipework. Is that all mild steel with black coating? That's not stainless steel? Otherwise I thought you would have gone for the shiny piping?
Are you going to get rid of the 80mm AFM and replace with a MAP sensor? I guess that depends upon what ECU you are running? I particularly like the heat shield around the exhaust housing. Was that custom made? If so, how much?
https://www.sau.com.au/forums/topic/22635-car-photos/#findComment-486774
Hippy, I doubt it ever will.
EVOIV: thanks. the manifold is mild steel, everything else was done in stainless including the dump, except for the hills plenum of course. I had it all ceramic coated, plus I will be heat wrapping the dump too. I would have had it coated even if it was stainless, as I like the idea of keeping the gasses moving as fast as possible. I went mild as I didnt see the need for stainless on the manifold.
I am running power fc, and I would like to keep afm. The heat shield was custom made, I shall check to see how much it was. I had so many things done at once it is hard to remeber what each bit cost:)
https://www.sau.com.au/forums/topic/22635-car-photos/#findComment-486798
Just a question, why would you want to keep the AFM if it restricts air flow, even slightly - being 80mm? Also, I know that the Japanese Power FC can come with a map sensor. Do you know if it's possible to get that? Or, you can do what AutoBarn's 180 did (before). Which was use the AFM after the intercooler, don't know how well it worked...but the car made great power. That way you could use a full 100mm pipe from airfilter to turbo.
I think the mildsteel manifold was a good choice as I've heard that stainless ones are more prone to cracking, just like mine did ;) What's next on the mod list? :) Will be good to see what results your car makes. I'm sure it will make a bucket load.
But do you find that the car is substantially laggier than normal? My car was a slug off boost. Felt slower on the road, unless I really pushed it on boost.
https://www.sau.com.au/forums/topic/22635-car-photos/#findComment-486823
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
