Well it's finally happened, my stock turbo started to show signs of harsh treatment:D
I lost about 3litres of oil since I serviced it last, about 5000kms ago, and therefore did a leak-down test, expecting a broken ring-land, but the engine was fine, so it was down to a turbo seal.
I made the decision at lunch-time today that I'd replace the turbo, and at about 3pm started work on it. By 5pm we had the turbo and manifold off. I already have the turbo (GT30), and external wastegate(45mm), the manifold should be ready by Monday.
I'm sending the dump, manifold and exhaust housing to be ceramic coated. Putting in bigger injectors and fuel pump.
With luck, and all going well I'll have much more power for the drift day, and a car worth putting on the dyno for PAS.
Looks like my dreams of 12's on the stock turbo are gone, I might aim for 11's now:D
https://www.sau.com.au/forums/topic/22639-pwptf-gets-a-new-turbo/
  • Replies 120
The wastegate will be off the manifold, and will be dumping to atmosphere like they all should:D
I wasn't dissappointed about the stock one dying, but would have like to have run a 12 with it, but with sticky tyres and 400rwhp I'll try for an 11:D
400rwhp??? please don't tellme you are going to go for that on stock internals and injectors or you will be up for a mortgage onyour car like SLY at the moment! i hit 295 then all that funny stuff happened as your well aware!..... we think it might be the valve spring, pistons look ok but a few signs of wear... hmmmm with 400 rwhp i might be able to pull a 14.1 HAAHAH!!!
let me know how you go dude!!!
Guest IHaveAnR33
i have an R33 stock hasb't had many mods at all 30,000 on the clock but only running very low boost about 3-3.5 a friend had a look under the bonnet and told me it had a boost restrictor. unplugged that and it was running 7 psi now the car runs odd. Splatters a bit, when i accellerate some times it is smooth and after a while it feels like the car is running almost like it has dirty fuel in it. would i need to have the car tunned in after bypassing the restrictor??
Are you talking about 7 on the stock guage? The stock gauge isn't in psi it's in 100mmHg, therefore 7 is actually about 700mmHg, or 1 bar.
The reason it splutters is due to overfuelling by the stock computer as you have raised the boost, it's very common.
BTW, if you want anymore help then start a new thread.
I just came back from visiting my car. I could have had it back tommorow if I hadn't decided to get the ceramic coating done, but never mind:D
The manifold is complete, with it's 45mm external wastegate. A new dump has been made, and a few changes to the intercooler pipework we're necessary. We removed the ABS to better position the external wastegate. The dump, manifold and exhaust housing are off to the ceramic coater tommorow.
The Bosch 910 fuel pump with surge tank is going in tommorow. Still waiting on a fuel rail to put the 550cc injectors into.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
