Well it's finally happened, my stock turbo started to show signs of harsh treatment:D
I lost about 3litres of oil since I serviced it last, about 5000kms ago, and therefore did a leak-down test, expecting a broken ring-land, but the engine was fine, so it was down to a turbo seal.
I made the decision at lunch-time today that I'd replace the turbo, and at about 3pm started work on it. By 5pm we had the turbo and manifold off. I already have the turbo (GT30), and external wastegate(45mm), the manifold should be ready by Monday.
I'm sending the dump, manifold and exhaust housing to be ceramic coated. Putting in bigger injectors and fuel pump.
With luck, and all going well I'll have much more power for the drift day, and a car worth putting on the dyno for PAS.
Looks like my dreams of 12's on the stock turbo are gone, I might aim for 11's now:D
https://www.sau.com.au/forums/topic/22639-pwptf-gets-a-new-turbo/
  • Replies 120
The wastegate will be off the manifold, and will be dumping to atmosphere like they all should:D
I wasn't dissappointed about the stock one dying, but would have like to have run a 12 with it, but with sticky tyres and 400rwhp I'll try for an 11:D
400rwhp??? please don't tellme you are going to go for that on stock internals and injectors or you will be up for a mortgage onyour car like SLY at the moment! i hit 295 then all that funny stuff happened as your well aware!..... we think it might be the valve spring, pistons look ok but a few signs of wear... hmmmm with 400 rwhp i might be able to pull a 14.1 HAAHAH!!!
let me know how you go dude!!!
Guest IHaveAnR33
i have an R33 stock hasb't had many mods at all 30,000 on the clock but only running very low boost about 3-3.5 a friend had a look under the bonnet and told me it had a boost restrictor. unplugged that and it was running 7 psi now the car runs odd. Splatters a bit, when i accellerate some times it is smooth and after a while it feels like the car is running almost like it has dirty fuel in it. would i need to have the car tunned in after bypassing the restrictor??
Are you talking about 7 on the stock guage? The stock gauge isn't in psi it's in 100mmHg, therefore 7 is actually about 700mmHg, or 1 bar.
The reason it splutters is due to overfuelling by the stock computer as you have raised the boost, it's very common.
BTW, if you want anymore help then start a new thread.
I just came back from visiting my car. I could have had it back tommorow if I hadn't decided to get the ceramic coating done, but never mind:D
The manifold is complete, with it's 45mm external wastegate. A new dump has been made, and a few changes to the intercooler pipework we're necessary. We removed the ABS to better position the external wastegate. The dump, manifold and exhaust housing are off to the ceramic coater tommorow.
The Bosch 910 fuel pump with surge tank is going in tommorow. Still waiting on a fuel rail to put the 550cc injectors into.
    • This sounds like a perfect excuse to install a Haltech R3.
    • I do believe from context he is talking about a S0/S1 R33 RB25 with associated ECU and Wiring for that, and a manual gearbox into a R34 N/A Auto. I don't have the knowledge of all the pinouts and such but my gut feeling from doing my own conversion is to use as much of the R33 stuff that you can. The "car" wiring is quite seperate from the "Engine" wiring when all things are considered. The only things to truly consider 99% of the time is the cluster, reverse lights and potentially disabling the 'not in P/N' immobilizer circuit.
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
