Don't happen to have the power window switch for the rear doors? Need one mainly for the rear left door as mine seems faulty.
yes i do, it's the silvery/grey colour. $30 plus postage
D.
  • 2 months later...
  • Replies 92
Posted Images
  • 3 weeks later...
rear bar, no.
collumn surround, yes, looks perfect to me, $40 plus postage
i have the front seats for sale, great condition except for one very small hole on drivers. make an offer.
also front and rear diffs, tailshaft, front driveshafts (from diff to wheels)
D.
Edited by pintaline
Excellent, that's the two pieces (upper/above column and lower/underneath column)? ...I don't suppose I need to check that it's in black? If yes to these please PM me payment info; postage would be to 5159
Thanks
DaveB
Gday, have you got the grey tiptronic selector cover, the grey cover with the PRD23 etc, as my clips are all broken. thanks.
and also the metal fuel filler tube ? thanks again
dave, yeh it's black. i'm flat out this week, will get onto a quote for you on monday
chook, yeh i have the cover but from memory it has a small scratch in the paint...? ill have another look and get back to you. if you're not fussed by that, $30+postage and it's yours
D.
D.
No worries Dave, I've got about a ~2 week wait on some locks (repairing damage from break in) to get here from Japland; so next Monday should be good :laugh:
DaveB
just checked the cover and it does have a tiny scratch but all clips are in good condition. fuel filler tube, $20
got front brakes?
calipers and discs? ship to Adel?
yes i have complete front brakes, calipers are good, discs are a bit worn, does anyone know the minimum thickness? i can have them checked and even machined if you really want
D.
12mm from memory, but could also be individual to the disc or vehicle.
Brake shop sould know.
Most discs (standard) i've seen have a little raised stamp somewhere ie. 'min-12mm'
p.s. Niiiiiiiice R31 in your pic! wish I still had mine :)
Edited by Stagea_Neo
lol cheers, i love my 31s... that pic was taken on the top of mt. panorama on an r31 club cruise, it's also a tv star... they were recording a bit about r31s for some show on fox and my car was one of the few they put in the show. sadly, it was written off about a week later by a hyundai excel. god damn excels!!! i have 2 other 31s at the moment tho, among other things...
D.
Hi,one question ,do you have the side indicators?are they the clear/smoked ones?If yes ...price? with postage to 3805,vic.?thanks...
calipers and discs, $150? and if postage isn't too much, ill chuck that in for free.
i had clear ones... but they went on my car. only a set of orange left. no cup holder either, putting that into another car
D.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
