Theres a new LPG system recently introduced to Australia, it's called Liquid Injection LPG where the LPG is directly injected into the intake manifold/plenum, replacing the old skool mixer system where previously gas was transfered into vapour form then straight to manifold, reducing engine power out put and consuming 25% more gas.
Apparently the new system is not only more efficient and hi-tech but according to some dyno result, it pumps out more power than petrol.
Have a read through this.
The system does not run a ECU, its only a ICU which means it only switches the gas injectors on and the petrol ones off. The gas injectors are run by the petrol computer purely. There is no separate tune. If you need a tune you flash your ECU like normal. So just think what can be gained with a proper tune.
The Terrritory donut tank is just a proposition at this stage. The brackets for donuts on Territories needs to be sorted.
The system is deceptively simple but complex in fitting correctly. I have only been around LPG for close to 15 years, and this , I would have to say, will revolutionise the industry totally.
I have been waiting for liquid injection to be released for a very long time now (years and years) and to have it so close to its release date is exciting ,to say the least, for me too.
So far it has lived up to my expectations and flown way above them. I really want to fit it to my own car also, that way I have a better feel for what it does and what claims I can make about economy and so forth first hand (it is being marketed with a 5% increase in economy over petrol) but who cares, its cheap AND..... IT GIVES YOU MORE POWER!!!! Who need to know more!!!!
As promised here are some pics.
Donut tank in the back
Edited by Barbarian
Sorry.. where are you pulling $10,000+ from here??
and last time I checked, Ford Territory's were Australian.
There was another thread around here about Mark converting his GTR... yeah they look good - if you're able to buy a kit specifically for the skylines that would definitely be a juicy option.
If it is liquid injection its obviously in a thicker form (as well as full time injection cycles) resulting in more LPG being burnt - I wonder how much mileage you would get in relation to unleaded?
Edited by -R33GTS-
No, because it would be illegal. Unless you paid the $10,000+ to get the car emission tested. And it isn't in Australia yet.
Emission testing what?
LPG doesnt require it, it never has. NFI what your on about
Im pretty sure ford has a series with liquid lpg. My old man loves them and I believe his falcon has it (company car) not 100% sure but anyways yes its true, Gas is more powerful with liquid
Nah not liquid unfortunately, still the mixer system in the Fords I'm pretty sure. But the liquid system above seems very promising. Bring on the results on paper :O
Ford still use the mixer system, the injected lpg system hasnt been around as long but i reckon it would pretty much hold up fairly well, the LPG is a good fuel source but anythime you try run a duel fuel setup you will get a head ache ignition timing cam specs the whole lot have to be a little bit different for each so you end up with a compromise and neither fuel supply gets you running 100%
All cars that have been converted to gas have to comply with the ADR's for emissions. The companies that make the kits pay for all the R & D and have the cars emission tested. Then and only then can the kits be sold to the public. That's why all diesel cars converted to LPG are illegal. As none of the kits are ADR approved yet. So the workshops that fitted them are either having to remove them or have the cars emission tested, which is very expensive.
  • 2 months later...
Wrong all cars pre 2004 dont need an emission test, only after 2004 do they need an adr compliant system, so yes you can convert your skyline and im in the process of doing it to my gtr using liquid injection,
  • 1 year later...
There is thread and threads on this stuff at Calais Turbo and the Ls1 forum alot of guys have been doing this to their 6lts and picking up a fair whack of KW's just from going to gas injection,
Ford still run mixers and you can get their EGAS falcon which is a straight gas mixer system with 2 tanks with a combined capacity of about 100lts. on trips i used to get around 550 - 600klms on that system, but would love to see what can be achieved with Liquid
Hi Guys,
Here is my r33 s2 gtst25 running JTG liquid injection for those interested. Runs great besides running a bit rough on a cold start until it warms up.
Cheers,
Nice one!!!
How much was the set up? Was it difficult to set up/tune?
Are you getting better fuel economy?
Cheers
Justin
Hi Guys,
Cheers,
Just wanna know two things.... is it a dedicated LiLPG system or is it dual fuel and if it IS a dedicated system, who did it?
Cheers.
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
