Good call, this forum eats up and spits out workshops that try to get work off of here.
Do some searchs on workshops that have tried to help members in the past, most of them have moved on from here never to return.
You will be the flavour of the month while you are giving them forum member discounts, then another shop will undercut you to get the work and BOOM you were a rip-off and you will get bagged and dumped.
Not all members of this forum are users and abusers, but a few bad apples as they.
Very well said... :)
very much agreed
we are not here to try undercut any other workshop
you will also never hear us bad mouth another workshop as it is not professional and we well and truly understand the effect word of mouth has in this industry
im sure our pricing will be very similar to amec - we are just perhaps a closer option for northside members.. ourselves and amec may perhaps be mroe expensive than some other fly by night trader workshops, but the quality of work and after sales service is second to none !!!
and whilst we are fairly new to SAU, we have hundreds of satisfied customers on the nissansilvia and hardtuned network
also we have heard nothing but praise from amec and we send all our 300zx work there - very much a specialty and no one does them better!!!
ALSO IF ANY ADMIN READ THIS - PLEASE CONTACT US RE FORUM SPONSORSHIP - I HAVE BEEN TRYING FOR MONTHS NOW TO GET HOLD OF SOMEONE TO JOIN AS A FORUM TRADER AND SPONSOR BUT NO ONE WILL GET BACK TO ME! TELL ME WHERE TO PAY AND I WILL !!!
thank you for listening :rolleyes:
thank you for listening :)
I'll try again to get someone to contact you mate... really sorry for the stuff around. If I could sort it out for you myself I would ;)
if anyone wants the idler and tensioner bearing parth numbers here they are
much cheaper than genuine nissan items
Tensioner: NSK 60TB 0683 EA7L 806 $28
Idler: NSK 56TB 2801 B01 $48
think nissan would want a couple of hundred for them
no worries guys
and most bearing places can get gates racing timing belts for under $100
Edited by neo32
yep 100K service will be the same price $953 including parts and labour :)
will do the rocker cover gasket for $85 + cost of the gasket.
I was quoted rocker cover gasket 2 hours 170 + cost of gasket when I was at your place.......-_-"
can't you make mine same as the above pricing?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
