HKS said to put springs for over 10,2 lift!
My cams are only 9,32 lift..
I search hks catalogs and they sells "hks pro cam valve springs" for 11.6lift and "hks step 2 valve springs" for 10.2 lift
I need or not?
My cams maybe they are very old? Because in the catalogs of hks there aren't 9.32 cams!
There are 8,7 10,2 and 11,6.
Anyway my head was bolted to the car and it is very very difficult to put now springs and I will need again new gasket! But if I need them I will do it!
Edited by GreeceS13
This cams was in the engine and I didn't know it..
Why you ask me? You don't like them?
There aren't HKS step 1 springs!
HKS produce springs step 2 and over...
So for my cams? Stock springs? As with hks step 1 8.7mm lift cams?
My cams are 9.32 and the step 2 is 10.2!
it's the stock valve guides that will die first. i wouldn't take it past 8000 if they haven't been replaced- they are fairly brittle in standard form, and only get worse over time with all the heat up and cool down cycles.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
