  • Replies 55
Guest Robo's
Searched the internet last night in trying to find some results in any performance gain, but couldnt find anything in comparison with a dyno with any gain!!
Yes the theory sounds right, and a good example was, "hot oil flows quicker then cold oil" which was used as a reference to exhaust gases.
But i was looking for an actual, real to life gain, and couldnt find anything.
That would be great.
If someone can post some before/after dyno results of the non/heat wrapped or even some before/after temps it sounds like a cheap effective modification.
When you guys say it makes the turbo spool quicker are you talking 100-200rpm or 500-700rpm ?
i had the same problem, changed my dump/front.........
if you want some real life proof: before i put the tape on i could smell burning plastic all the time and id lift the hood and it would be as hot as **** under there, and after i put on the tape the burning smell went away and it is no where near as hot under there anymore..
good idea if you ask me :D
The biggest thing I'd be concerned about is the exhaust rusting from beneath the heat wrap because of condensation. Can you get your exhaust painted/coated with heat resistant stuff while it's on the car? And then put the thermal wrap on top of that.
Although, my exhaust is stainless anyway, would that be resistant enough to corrosion?
Exhaust wrap is good stuff in my experience. When coating headers, the headers would still get hot and I would imagine you'd still burn yourself if you were working in the engine bay after the engine was running. The wrap on my exhaust previously allowed me to work in the engine bay after the engine was running if I had to with minimal worries. You could even touch the manifolds themselves without burning your hands - of course you couldn't leave them there very long!
I find it interesting that most Japanese tuning houses and drag cars use header wrap.....
GTS-t VSPEC, a guy in these forums (sorry I forget who) had his exhaust rust right through from beneath his heat wrap. He didn't say if he had mild or stainless though I think.
The problem is not condensation while driving obviously, but after you park and it cools down. It probably won't be a *major* problem if the car is garaged but heat wrap being cloth and therefore porous, it will absorb small amounts of water from the air especially when it has the cold metal underneath to help the condensation in the first place.
Anyway I'm pretty sure stainless will be ok. It's not rustproof, but it's rust resistant which is probably enough. It may be my biggest concern but it's probably not a major one :P
Tomeastlake81, so you can heat wrap the exhaust manifold too? How do you do that?
There is a little theory floating around about the increase in performance from coating and wrapping the dump pipe.
My thoughts are that as a hp modification its not worthwhile. Full stop. The theory about exhaust gases etc is correct, but if coating/wrapping was going to make a measureable performance gain then it is most likely going to be seen if done to an exhasut manifold. And then even most likely on a stressed race engine more then a road car.
But again i see the main reason for coating exhaust parts is in the search to drop underbonnet temps. There is numerous reasons alone why we should be trying to drop underbonnet temps. If you want performance increase then consider about every 4deg C at the inlet is worth approx 1% of engine power.
Has anyone ceramic coated the standard manifold ? Mine is pretty rusty and would require a bit of work to get it nice I guess - But I like the idea - Then ceramic coat the dump plus thermal wrap it !
The stock manifold is cast and is poorly designed. I wouldn't waste the money on it. Doing the dump then thermal wrapping it make sense though.
The other option is to have the manifold heat sheild ceramic coated, they would reduce the amount on heat radiated into the engine bay from the manifold.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
