  • Replies 167
Posted Images
Reckon me and missus should be there, about time I turned up to one of these and met a few new peoples, hopefully by car will be back on the road by then else it'll be the Excel FTW! :laugh:
excels r fooly sik uleh :P
-D
im a part time northerner :laugh: Since im at lukes half of the week.
I must be one of the only ones that lives central to the city?
Anyway, looks like this is going to be a good turnout this time, if everyone thats said they will come actually turns up this time :P
Reckon me and missus should be there, about time I turned up to one of these and met a few new peoples, hopefully by car will be back on the road by then else it'll be the Excel FTW! :(
hey ash what you been up to mate? haven't got the bike anymore, last time we caught up you were hobbling around schutzenfest on crutches
flick should be able to let you know by friday night, its good working in the city now don't have to drive from way down south for the dinners :)
was anything happening afterwards? i hear there's talk of buckhunter, i want a rematch andrew after the pool night
Might be in for this. Its a maybe at this point. If ya make the booking, we will just eat at a diff table and meet n greet afterwards. Havnt seen u and luke for ages and havnt met anyone else so would be good. If a mate says he can come then yeah, can stretch the legs on the GTR. (if its not in getting mods that is :D) so dont add me to the list, but yeh, may make an apperance ;)
