  • Replies 167
Posted Images
Reckon me and missus should be there, about time I turned up to one of these and met a few new peoples, hopefully by car will be back on the road by then else it'll be the Excel FTW! :laugh:
excels r fooly sik uleh :P
-D
im a part time northerner :laugh: Since im at lukes half of the week.
I must be one of the only ones that lives central to the city?
Anyway, looks like this is going to be a good turnout this time, if everyone thats said they will come actually turns up this time :P
Reckon me and missus should be there, about time I turned up to one of these and met a few new peoples, hopefully by car will be back on the road by then else it'll be the Excel FTW! :(
hey ash what you been up to mate? haven't got the bike anymore, last time we caught up you were hobbling around schutzenfest on crutches
flick should be able to let you know by friday night, its good working in the city now don't have to drive from way down south for the dinners :)
was anything happening afterwards? i hear there's talk of buckhunter, i want a rematch andrew after the pool night
Might be in for this. Its a maybe at this point. If ya make the booking, we will just eat at a diff table and meet n greet afterwards. Havnt seen u and luke for ages and havnt met anyone else so would be good. If a mate says he can come then yeah, can stretch the legs on the GTR. (if its not in getting mods that is :D) so dont add me to the list, but yeh, may make an apperance ;)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
